Serenity Solderless kits! - Jemsite
post #1 of 14 (permalink) Old 08-31-2011, 05:08 PM Thread Starter
I am really bad at soldering, so I wanted to find a solderless kit. It wasn't a quick find, as I can't find anyone else talking about this kit. Its expensive, 70-80$ but you get alot of options. Youll just have have look for yourself. http://www.toneshapers.com/Webpage.aspx?WebpageId=71 . Def interested in this kit and I plan on getting at least 2. To fix the wiring issues in my 2 squier stagemasters.
ComeAlone is offline
post #2 of 14 (permalink) Old 08-31-2011, 06:01 PM
Reviews: 64
Re: Serenity Solderless kits!
No thanks.
I really don't know how somebody could be bad at soldering, it takes 5 seconds to put a wire over something and solder it.
6fingers is offline
post #3 of 14 (permalink) Old 08-31-2011, 10:15 PM Thread Starter
Um, it doesn't exactly work that way when all of your solder joints go cold and you fry your pots out because it didnt take 5 seconds to melt the solder, the solder simply wouldn't melt.
post #4 of 14 (permalink) Old 08-31-2011, 10:29 PM
Reviews: 64
That explains why you're bad at soldering
6fingers is offline
post #5 of 14 (permalink) Old 08-31-2011, 11:17 PM
elcid's Avatar
Hate to jump on the bashing train, but $80 switch on a $200 guitar?
I dont get people fear of soldering, even if you messed up and burned a pot, you can replace it 10 times for what the kit costs
elcid is offline
post #6 of 14 (permalink) Old 08-31-2011, 11:21 PM
Reviews: 64
+1
Maybe this could help.
http://www.youtube.com/watch?v=BLfXXRfRIzY
6fingers is offline
post #7 of 14 (permalink) Old 09-01-2011, 12:20 AM
If the solder won't melt, then you most likely didn't season/care for your tip correctly. I was having the same problems before I learned the correct thing to do.
Watch this video, it shows what you should do to a new tip before you use it.
http://www.youtube.com/watch?v=EFXYpxYrvyI
Also, what kind of solder are you using? Don't use that cheap **** that comes with the soldering iron.
xXLinkageXx is offline
post #8 of 14 (permalink) Old 09-01-2011, 06:59 AM
I thought I was really bad at soldering for years and was scared to do it. Turns out I just always had crappy soldering irons. Once I got a decent soldering iron I found it to be pretty easy.
EvilEmuOfDoom is offline
post #9 of 14 (permalink) Old 09-01-2011, 07:07 AM
1) use a decent iron
2) season the tips
3) order some lead solder and forget the rosin junk.
For something that you may need to solder and unsolder multiple times, rosin core solder is not the thing to use. Lead solder works much better and is easier to use. It's just a little pricey and harder to get a hold of.
gideond is offline
post #10 of 14 (permalink) Old 09-01-2011, 08:51 AM
If you need to solder and unsolder multiple times with rosin core solder, a desoldering braid is a must.
http://www.radioshack.com/product/in...ductId=2062744
post #11 of 14 (permalink) Old 09-01-2011, 09:49 AM Thread Starter
All I can say is that I think its a cool modification, and I don't have to worry about buzzing and grounding issues, so its worth it to me.
post #12 of 14 (permalink) Old 09-01-2011, 09:54 AM
I still think it's a cool idea and perfect if you're like me and like trying new pickups frequently. However, their price is a little ridiculous.
post #13 of 14 (permalink) Old 09-01-2011, 04:12 PM
Reviews: 120
Get a Seymour Duncan Liberator and have a friend who can solder install it for you. Then you can switch pickups around to your hearts content without busting out the iron. It's a lot cheaper than those kits.
LonePhantom is offline
post #14 of 14 (permalink) Old 09-01-2011, 09:39 PM
Almost forgot the biggest problem with these kits. You better take some measurements before hand. They are often too large to fit correctly in the cavity without routing the wood out.
gideond is offline
serenity , solderless
For sale: EMG 85/81 set with EMG solderless kit aywilson Classified Ads: Guitars and Gear 2 07-24-2011 01:08 PM
Do it yourself kits DEADTUNES666 Tech: Setup, Repairs and Mods 5 02-01-2011 12:37 PM
DIY Keeley Mod kits? Inzane Gear, Equipment, Recording & Off Topic 4 08-27-2010 05:58 PM
Carvin Kits sanitarium All Other Guitars (including Prestige) 15 05-25-2006 03:28 PM
Carvin Kits sanitarium All Other Guitars (including Prestige) 23 07-22-2004 02:05 PM
