Seymour Duncan wont fit in RG7420! Help! - Jemsite
post #1 of 6 (permalink) Old 05-02-2008, 02:07 AM Thread Starter
Reviews: 6
Question Seymour Duncan wont fit in RG7420! Help!
Hi
Just bought a 7 string SD to fit into the solid body RG7420 but the pickup stand way to proud pushing the strings upwards - can i 'snip' the ends of the screws that stick through a good eighth of an inch under the pickup letting me modify the L shape legs lowering the pick up into the body without altering the sound of the pickup?
Cheers
RGOU812 is offline
post #2 of 6 (permalink) Old 05-02-2008, 02:28 AM
Ayrton's Avatar
Re: Seymour Duncan wont fit in RG7420! Help!
So the legs are too tall or the screws are too long?
Ayrton is offline
post #3 of 6 (permalink) Old 05-02-2008, 05:58 AM Thread Starter
Reviews: 6
Yep - the routing on the solid body isn't deep enough to let the pickup level to the correct height - i'd only have to snip about 1/16 of an inch of the protuding screws and i could alter the length of the legs a little and re drill suitable holes in the legs to suit the ones in the body, i was just worried in case trimming the ends of the screws would affect the sound even though the screw end are in fresh air.
RGOU812 is offline
post #4 of 6 (permalink) Old 05-02-2008, 11:00 AM
Reviews: 4
That's easy.
With a Dremel and the tiny router bit, make the routing a little bit deeper.
If you want, spray a bit of black paint on the bare wood, just to "hide" the bare wood.
Crazy_Guitar is offline
post #5 of 6 (permalink) Old 05-02-2008, 11:31 AM
On a 7-string, the legs shouldnh't be too deep, but the screws are definitely longer. Part of "traditional" tone on a humbucker is that the screw coil has stretches the magnetic field downward, and elongates it on that coil. Snipping the screws short is actually a preferred modification for some people. They do it on purpose for sonic reasons. If you don't want to snip the poles, you can also just drill 7 holes in the cavity under the poles. That way only the poles would be recessed.
frankfalbo is offline
post #6 of 6 (permalink) Old 05-02-2008, 05:09 PM Thread Starter
Reviews: 6
Thumbs up Re: Seymour Duncan wont fit in RG7420! Help!
Good idea - thanks, i was looking at routing the guitar but drilling holes under the poles and bending the L shape legs flat (as the original japanese pick ups were flat to the body) will solve the problem no end!
Cheers
RGOU812 is offline
Wiring problems with Seymour Duncan in a JEM Christoph_JEM Pickups & wiring 6 04-14-2011 04:45 PM
Seymour Duncan TB5/GFS 59 FS/FT!!! Shreddy Krueger Classified Ads: Guitars and Gear 1 02-03-2008 04:51 AM
eMG 81/60 and Duncan Distortion (Seymour Duncan SH-6) Fornicatron Classified Ads: Guitars and Gear 2 10-10-2006 10:09 AM
Seymour Duncan Pickups/Steinberger & Kramer Guitars Robotechnology Classified Ads: Guitars and Gear 3 07-18-2006 09:50 PM
seymour duncan pickup advice big h Pickups & wiring 7 01-17-2004 03:38 PM
