Single Coil S1 vs Dimarzio/Ibz RG-S - Jemsite
post #1 of 2 (permalink) Old 08-09-2018, 01:02 PM Thread Starter
Hi,
I'm wondering if someone have and experience with this two single coils pickups, mainly in 2 and 4 position of the 5-way switch (mixed with the humbucker in coil splited mode). Which should be better to get this strati "quack" sound?
From what I've read here
DiMarzio IBZ pickups | Ibanez Wiki | FANDOM powered by Wikia
Vintage (V & S) pickups | Ibanez Wiki | FANDOM powered by Wikia
S1 is alnico V and IBZ-RG-S ceramic.
Acording to dimarzio IBZ-RG-S
DiMarzio®/IBZ pickups | DiMarzio
"The R1 single-coil is warmer-sounding than a typical vintage single-coil, and was designed to work well with the neck and bridge humbuckers when they are in split mode. It has a sound similar to that of the HS-2™ in split-coil mode."
And ibanez wikia from S1 says:
"Traditional sounding, yet high output single coil with Alnico 5 polepieces for even string output. Designed to work with humbuckers in the split position."
hmoller is offline
post #2 of 2 (permalink) Old 08-09-2018, 06:28 PM
Re: Single Coil S1 vs Dimarzio/Ibz RG-S
S1 is pretty basic and mostly reverse wound for being in that middle position... it is not staggered like most "strat pickups" so it sounds pretty even accross the fret board... not sure i'd call it quacky but a little tone adjustment might help with that i have them in quite a few guitars matched up with dimarzio's, etc and they sounds great
"this is my opinion" i don't like stacked single coils in the middle because because they don't mix very well with a tapped humbucker you end up with something that sounds very tele in the 2 and 4 position (well.... unless you wire them backwards and i still don't like the way they sound)
sorry i do not have experience with the IBZ
hope that helps
LACS-plus is offline
dimarzio/ibz , ibz , single 1 , single coil
Dimarzio Tall Pickup Covers on eBay do they fit S1 single coil? PlayThickStrings All Other Guitars (including Prestige) 6 07-03-2014 11:24 PM
Consecuences of replacing a true single coil with a hum cancelling single coil? fosi_ Pickups & wiring 20 03-22-2011 03:37 PM
fs ibanez s-1 s1 single coil just42dave Classified Ads: Guitars and Gear 1 07-26-2008 03:37 PM
blocking s1 single coil on rg 1570 thc303 Pickups & wiring 12 10-10-2005 04:20 PM
Ibanez S1 Single Coil - Which wire is Hot!!! Vaibanez Tech: Setup, Repairs and Mods 2 06-06-2001 06:59 PM
