Spacing of the Seymour Duncan is wrong? - Jemsite
post #1 of 13 (permalink) Old 07-25-2012, 03:52 PM Thread Starter
Reviews: 10
Hey guys,
Recently I've fitted my Dean V with the usual SH4/SH2 combo, but the pole pieces don't align very well. The spacing is too wide for the neck and too small for the bridge. I have the gold covered pickups. Does any one of you have the same problem?
YJGB is offline
post #2 of 13 (permalink) Old 07-25-2012, 04:08 PM
Re: Spacing of the Seymour Duncan is wrong?
What kind of bridge? If you have a Floyd you need F-spaced pups.
kfssdude is offline
post #3 of 13 (permalink) Old 07-25-2012, 04:16 PM Thread Starter
Reviews: 10
It is a fixed bridge, and there is not even a trembucker version of the SH2.
YJGB is offline
post #4 of 13 (permalink) Old 07-25-2012, 08:22 PM
That sounds like a string spacing choice by Dean for that model rather than a problem with the Seymour Duncan pole spacing.
Petie is offline
post #5 of 13 (permalink) Old 07-25-2012, 11:18 PM
Reviews: 15
are you positive you don't have the pickups switched by chance? Sounds like the bridge pickup should be f-spaced and the neck should be regular-spaced. I had the same issue with my SZ720, which is also a fixed bridge.
silverctr is offline
post #6 of 13 (permalink) Old 07-27-2012, 12:08 PM
Wait you got the bridge version of the Jazz for the neck position.
reign_of_blood is offline
post #7 of 13 (permalink) Old 07-27-2012, 05:12 PM Thread Starter
Reviews: 10
They are not switched, because they were put in on a different day. It's not that bad for the bridge pickup, but the neck pickup has the low E pole piece positioned right, and the high E almost all the way off.
No, I am 100% sure I have the neck version. It said on the package, so I believe it.
YJGB is offline
post #8 of 13 (permalink) Old 07-27-2012, 05:45 PM
What bridge is it? Just because its fixed doesn't mean its not F-Spaced.
GuitarBizarre is offline
post #9 of 13 (permalink) Old 07-27-2012, 05:48 PM Thread Starter
Reviews: 10
It's a normal Tune-O-Matic, but the problem is that the pole pieces are too far from eachother, not too close.
YJGB is offline
post #10 of 13 (permalink) Old 07-27-2012, 06:35 PM
Reviews: 120
Modern tuneomatics are closer to F spaced, that may be the issue.
LonePhantom is offline
post #11 of 13 (permalink) Old 07-27-2012, 06:50 PM
yep....
Jamm'n Jimmy is offline
post #12 of 13 (permalink) Old 07-27-2012, 07:51 PM
Which Dean V model is it? I'd be interested to see the specs on the neck width from high E to low E.
Petie is offline
post #13 of 13 (permalink) Old 07-28-2012, 01:34 PM Thread Starter
Reviews: 10
That might be, but the bridge pickup isn't that much of a problem. The neck pickup is what bothers me, even if it is purely cosmetics. And the polepieces are too far apart, not too close together.
It is the V79 White Gold, which should have the exact same specifications as a Gibson, spacing wise.
YJGB is offline
dean , neck pickup , seymour duncan , spacing , wrong
fs/ft: Seymour Duncan 59' kshands Classified Ads: Guitars and Gear 2 11-15-2009 01:59 PM
Pole Spacing - Difference between F-spacing and ordinary spacing on dimarzion evo's corkyo4 Pickups & wiring 1 04-09-2007 07:36 AM
eMG 81/60 and Duncan Distortion (Seymour Duncan SH-6) Fornicatron Classified Ads: Guitars and Gear 2 10-10-2006 10:09 AM
FS: Seymour Duncan 7-string Duncan Custom pickup Scott of Actual Time Classified Ads: Guitars and Gear 2 04-09-2006 09:22 PM
Seymour Duncan JB/59 tmoori Pickups & wiring 11 03-22-2006 04:00 AM
