Split coils in 570 - Jemsite
post #1 of 5 (permalink) Old 10-10-2012, 07:00 AM Thread Starter
Split coils in 570
I bought a 570 on ebay a couple of months ago,
have given it a chance as it was well set up
but now its time to set it the way I like it.
Plan is to change the strings from 9 to 11,
put a Duncan p-rails in the bridge,
neck I am not sure, either put in a D-activator from my iceman or an Indie DV8 that I have in 3 other guitars and I like a lot.
Take out the middle single coil as it gets in the way.
Use this diagram for wiring but with a 1K pot.
http://www.seymourduncan.com/support...=2hb_1vol_5way
will this diagram work with the 5 way in a 570 ?
Maybe I would be better off replacing the tone with a DPDT switch for the P-rails ?
LostInRockFormations is offline
post #2 of 5 (permalink) Old 10-10-2012, 08:16 AM
Reviews: 120
Re: Split coils in 570
Yes that diagram will work. Maybe using a triple shot humbucker ring and a 3 way pickup selector might be a better way to go though?
LonePhantom is offline
post #3 of 5 (permalink) Old 10-10-2012, 09:57 AM Thread Starter
Thats a good idea, the diagram I was thinking of didnt give all the options for the p-rails.
still want to take out the middle pickup as I dont use it and it gets in the way.
I also suspect the mag field will cause a small loss of sustain, though thats probably not significant.
post #4 of 5 (permalink) Old 10-10-2012, 06:42 PM
Reviews: 120
Just lower the single all the way into the guitar so you don't have an ugly hole, and disconnect the wiring if you don't want to use it.
post #5 of 5 (permalink) Old 10-26-2012, 07:59 AM Thread Starter
all done,
Rio Grande Bstard RWRP P90 in neck,
but connected to middle on switch.
Iron Gear steel twin in middle,
Duncan P-Rails in bridge with 3way coil split switch.
Very happy with it, lots of good tones,
570 set up well with 11-48 and good action.
I even like the Iron Gear ,
I just put it in as a cheap way to fill the hole but it sounds good too.
5way 570 prails
Need help with splitting coils mr.death Pickups & wiring 8 05-12-2012 01:19 AM
Dimarzio, inner split coils ChaserHUN Pickups & wiring 1 10-30-2011 11:51 AM
WTB-Single Coils PU Kelly Briggs Classified Ads: Guitars and Gear 0 07-01-2011 12:26 AM
WTT/WTS: EMG S Single Coils Code001 Classified Ads: Guitars and Gear 4 08-01-2009 12:11 PM
What Single coils? yellowshirtguy Pickups & wiring 2 07-04-2009 05:26 PM
