Spliting Neck HB in position 4 on a 5 way switch - Jemsite
post #1 of 2 (permalink) Old 03-09-2012, 10:29 PM Thread Starter
Smile Spliting Neck HB in position 4 on a 5 way switch
I'm putting some new Dimarzios in a JEM, zebra color pattern, and I can't flip the neck HB because it's two different colors.
How do I wire the pickup differently so the other coil is on in position 4, without flipping it?
Thanks
Sebastian
sebastian is offline
post #2 of 2 (permalink) Old 03-10-2012, 08:44 AM
Re: Spliting Neck HB in position 4 on a 5 way switch
If it's wired red is hot, black-white is split, and green is ground. You can try:
1. Switching the red and green wires. This might be out of phase, though.
2. White is hot, red-green is split, and black is ground.
I'm really not sure how the single coils are wired. I may update this in a bit. Either way, both of those will select the opposite coil. One will give you a strong signal but you'll lose any hum canceling. The other will be out of phase but with hum canceling. This is why these pickups get flipped in the first place.
EDIT:
I am 90% sure the 2nd option is the one you want. It should sound the same as if the pickup was flipped but with hum like in 3rd position.
xXLinkageXx is offline
dimazrzio switch
RGA121 2nd Position Low Low? Anyone know know?% way switch problem. mattier303 Pickups & wiring 0 02-17-2011 01:04 AM
Could i change the 2 position switch of my RG620x to a 3 position switch? supergirl20_06 Tech: Setup, Repairs and Mods 4 05-10-2007 04:27 AM
RG620x could i change the 2 position switch to a 3 position switch without any mod? supergirl20_06 Pickups & wiring 6 04-25-2007 06:12 AM
3-position switch, 2 hum. wiring. john1880 Pickups & wiring 4 07-10-2006 08:02 PM
Old RG550 5-position switch Dman All Other Guitars (including Prestige) 3 05-04-2002 03:01 PM
