Super Distortion vs Dual Sound - Jemsite
post #1 of 5 (permalink) Old 01-29-2012, 01:20 PM Thread Starter
According to the blurb on the Dimarzio site, these two are both identical, except that the Dual Sound has the ability to be coil tapped.
now does this mean that the super distortion wont split it coils when the selector switch is in position 4, or does it just mean that the SD wont support the push/pull pot coil tapping?
rickybaby1985 is offline
post #2 of 5 (permalink) Old 01-29-2012, 01:40 PM
Re: Super Distortion vs Dual Sound
they are the same, both are 4 conductor pickups both can be tapped or run in parallel.
j.arledge is offline
post #3 of 5 (permalink) Old 01-29-2012, 02:09 PM Thread Starter
ok cool, thanks!
post #4 of 5 (permalink) Old 01-29-2012, 07:37 PM
When the Super Distortion first came out, you couldn't split it. The Dual Sound is a Super Distortion you where able to split and was released a few years later. The Super Distortion then changed over so you could split it. So, now it's just redundant to have both of them. Sales must be good for both, otherwise Dimarzio would have phased one out. They're probably hitting 2 different markets with them, the heavier crowd and the strat crowd.
xXLinkageXx is offline
post #5 of 5 (permalink) Old 01-31-2012, 06:16 PM
When you get a DP101 Dual Sound, you're also receiving in the container a switch which can be immediately used to facilitate the extra modes of wiring - used to be a mini double pole switch, and nowadays you'll find a compact format push pull pot, 500k with a DPDT switch.
That, the name and model numbers are, as already pointed out, the only differences; the pickup itself is identical.
steve is offline
(WTB) DiMarzio X2N and DUAL sound/super distortion humbuckers! F-Spaced fireheart82 Classified Ads: Guitars and Gear 0 04-02-2011 10:35 AM
WTB: 36th Paf, Super Distortion, Super 3 Thrash Classified Ads: Guitars and Gear 2 03-20-2009 10:11 AM
Super Distortion S Mr.Fast Pickups & wiring 0 02-18-2009 07:19 AM
FS: Priced to move ASAP brand new MXR Dual Shot Distortion ibanezcollector Classified Ads: Guitars and Gear 2 10-20-2006 08:02 PM
Super Mario on dual PGMs Patrick Deno Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 27 03-20-2006 03:55 PM
