Swapping V7 for Duncan JB wiring help - Jemsite
post #1 of 3 (permalink) Old 01-07-2016, 01:58 PM Thread Starter
Hi not been on here for a while but I'm upgrading my trusty Ibanez RG1570 with a Jb trembucker. Wiring is slightly different and whilst I appreciate there are loads of topics I can't find the answer to what I need.
My question is do I follow the Seymour Duncan wiring diagram or do I use the wiring diagram for the guitar?
Duncan instructions are to solder red and white together but the V7 red and white wires were soldered on either end of the 5 way switch.
Any help would be really appreciated, thanks.
phil27 is offline
post #2 of 3 (permalink) Old 01-07-2016, 04:40 PM
Reviews: 120
Re: Swapping V7 for Duncan JB wiring help
Do you mean the V8? The V8 is the bridge pickup. With wiring the JB into your guitar first solder the red and white wires together. From memory the later model V series used red as hot, solder the JB's black to that spot (Should be the wire from the V8 on the last spot on the switch), depending on the vintage of the V8 though it could be white. And then wire the red/white wires on the JB to the other spot on the switch (the V8's white wire, or red depending again on the vintage). The bare and green wires of the JB go to the back of the pot to ground the pickup. Basically if the JB doesn't sound big and full you may need to switch the black and red/white wires over, no big deal.
LonePhantom is online
post #3 of 3 (permalink) Old 01-07-2016, 07:06 PM Thread Starter
Re: Swapping V8 for Duncan JB wiring help
Yeah sorry meant the v8. Wired it up like described and it does sound a little thin and not as hot As the v8 so guessing wires are round wrong way also there is a constant hum from the pickup. Will try and swap wires round.
Thanks very much for the advice.
phil27 is offline
duncan , ibanez , rg1570 , trembucker , wiring
Duncan Designed Wiring Confusion Agenthoover Pickups & wiring 1 08-23-2011 08:39 PM
Wiring problems with Seymour Duncan in a JEM Christoph_JEM Pickups & wiring 6 04-14-2011 04:45 PM
Need help wiring Duncan and Dimarzio in my RGA121. mityjoeyoungxnj Pickups & wiring 2 11-06-2006 05:40 PM
Wiring Help Needed - Swapping EVO for EVO2 fyrie Pickups & wiring 5 09-25-2005 11:56 PM
Duncan Trembucker.... - wiring question jeff l Tech: Setup, Repairs and Mods 4 05-18-2001 11:48 PM
