TAPPING the Crunch Lab and Air Norton S - Jemsite
post #1 of 3 (permalink) Old 06-01-2012, 02:55 PM Thread Starter
Dear Jemsite Gearheads
OK, so I have this ESP M-II Custom, a neck-thru beauty in Alder.
Right now it seems to have a Duncan JB and ESP-logo Cool Rails. That would be a Hum-Single setup for those of you in Rio Linda. (although Technically hum-hum from a functionality point of view). Controls are a 500k volume pot and a 3-way toggle.
Right now I have the following on order:
Dimarzio Crunch Lab (F-spaced of course, for my weird Sinclair Floyd)
Air Norton S, for the faux single coil neck position
Dimarzio 500K push-pull pot
So as you can probably guess, I am planning on wiring this up as a hum-hum setup, with the push-pull functioning as a coild tap for both pickups.
So here's where I might need some insight from a coil-tapping expert, or someone familiar with Petrucci setups. Petrucci installs his new pickups, whether D-Sonic or Crunch Lab, upside down, so the bar is closer to the neck. If I do a coil tap setup, I usally wire it so the inside coils are live when split. Now, if I go and turn the bridge pickup upside down like JP, I'll have to wire up what's normally the outer bridge pickup coil, since now that's on the inside.
So here's the question, any pitfalls with that? Any chance that the bar coil will sound less than ideal when split, and maybe I'm better off wiring up the (now) outer coil so that the coil with pole pieces is hot?
And has anyone on these forums ever split a Crunch Lab or an Air Norton S, and can say if either one sounds any good like that?
Best Regards fellow sick guitar freaks
JShred is offline
post #2 of 3 (permalink) Old 06-05-2012, 12:24 PM Thread Starter
Re: TAPPING the Crunch Lab and Air Norton S
I guess I'm exploring in the unknown with these pickups in this type of wiring.
Well, I got all my parts and hardware yesterday, and the installation is done.
Everything worked out great. I used a Dimarzio 500K push-pull. I have it set up so the inner coils are isolated when I pull the pot. Everything sounds great. I do like the Crunch Lab, although it's going to take some getting used to, as the pickup is fairly understated in its tonality, it doesn't chug, woof, screech or scream. It's actually a fairly predictable and consistent pickup, with great organic musical harmonic overtones. I am surprised that the Air Norton S sounds and functions so much like its full sized big brother, which I love. Bite and pinch harmonic squeals on a neck pickup, never a bad thing. What's most surprising is the blended position on the switch sounds great for almost all Petrucci leads. It's a sweet blend of warmth and definition.
I think all I have to work on is how to get the faux single coil to sit a little closer to the strings. I'll have to make some kind of shim, probably cut down a couple popsicle sticks or something.
If anyone considers this combination for an HS guitar and want more insight, hit me up.
JShred is offline
post #3 of 3 (permalink) Old 02-10-2016, 08:49 AM
Long shot here! Was some time since this thread was active...
But I'm really curious on the same pickup combo in my hss Charvel and thought your tone preferences might be close to my needs.
I'm a sevenstring metal player but am just about to freshen up my Adrian Smith Jackson for a really stratty tone with a Paf pro and two area 58's.
After that I wanna make my Charvel hotted up a couple of levels above the Adrian so to say. My goal is to make them cover the areas in my metalbands that might not be so very metal. Probably the Adrian for some cleans or crunchy leads and the Charvel for more heavy, yet "toneful" leads. I also do regular rock in a folk style and think they both Should cover that then aswell!
What are your thoughts on my idea with the choices of pickups for my Charvel for that? Also does anyone have a suggestion of middle pup? Perhaps hs-3? (Said to b close to the Vai Evo mid single). That might give me some good combos with both crunch lab bridge and ANS neck?
Hope you're still around = )
Jonatanberg is offline
air norton s , coil tap , crunch lab , dimarzio , pickups
Crunch Lab, Liquifire combo VS Air Norton, Steve's Special FOA_Mikey Pickups & wiring 11 08-28-2011 12:27 PM
Custom Ibanez: Alder or Basswood body with Crunch Lab and Air Norton?? kanc All Other Guitars (including Prestige) 3 06-02-2010 10:58 AM
Tapping stuff, Part 2 - Cool legato tapping pattern :) Jay Satriani Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 01-11-2002 07:48 AM
Tapping stuff, Part 1 - Cool petrucci style tapping pattern Jay Satriani Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 01-11-2002 07:22 AM
Tapping examples - Tapping Patterns Jay Satriani Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 08-28-2001 04:30 PM
