Is there a specific type of wire needed to wire a guitar? - Jemsite
post #1 of 7 (permalink) Old 04-03-2010, 10:40 AM Thread Starter
Reviews: 18
I do not know much about wiring a guitar or electronics since i have never wired one, so i was wondering if there is a specific type of wire needed for wiring a guitar. I want to take some wire from an old pedal that doesny work any more
IBNZ_RG is offline
post #2 of 7 (permalink) Old 04-03-2010, 11:01 AM
Re: Is there a specific type of wire needed to wire a guitar?
I've heard anywhere from 18-22 is acceptable. other than that, i haven't heard any other "tips", not even something like brand names.
hellboar is offline
post #3 of 7 (permalink) Old 04-03-2010, 11:17 AM
Wire is wire, it all conducts so its all good ( barring obvious things such as big size differences and things like that). It is just a tube of metal with some rubber thrown around it.
So yeah, taking wire from another thing and using it somewhere else shouldn't be an issue. If you're in a pinch and need something fast you can just cut apart old headphones, extension cords, etc.
Magical Muffin is offline
post #4 of 7 (permalink) Old 04-03-2010, 11:52 AM Thread Starter
Reviews: 18
Okay! Thanks guys! Just wasnt sure!
IBNZ_RG is offline
post #5 of 7 (permalink) Old 04-07-2010, 08:33 PM
I'm in a similar situation too. So if I went to this website: maplin.co.uk/Search.aspx?menuno=12278&MenuName=Equipment%20Wire , which would be suitable for wiring to/from pots and a switch?
Thanks,
Ryan.
Ryann is offline
post #6 of 7 (permalink) Old 04-13-2010, 11:49 AM
I've actually done a comparison between Radio Shack clear coated, stranded speaker wire and Allparts "guitar wire" for a rewiring. It made no difference to my ears. The speaker wire is still wired in there.
I used to believe that the thicker the wire used the more receptive the circuit becomes to interference especially on the hot wires from the volume pot.
However the component compartment in this guitar is lined with grounded copper tape....
slartibartfast is offline
post #7 of 7 (permalink) Old 04-18-2010, 01:48 AM
wire is pertty much wire, i have never noticed a difference but when running longer wires like going to a switch in the les paul i strongly recommend using a shielded wire . shieled means that there is an outer wire that you ground with an inner wire that is a conducter. All pickup wires (99%) have shielded leads. Shielded wire protects against interferance (60s cycle hum) . you can also shield your guitar (if it isn't already shielded) with adheasive backed copper foil.
j.arledge is offline
ibanez , rg470 , wire , wiring
FS: My last X-wire (Wireless Guitar System) DavejWeiner Classified Ads: Guitars and Gear 3 12-11-2007 04:36 PM
Rewiring Job: What wire is good wire? Gex Tech: Setup, Repairs and Mods 3 06-11-2005 01:01 PM
Wiring help needed again - Tele pickups to wire aerocol Tech: Setup, Repairs and Mods 10 04-14-2002 05:44 AM
extra (?) ground wire - is it needed? GreasyKid Tech: Setup, Repairs and Mods 3 02-23-2002 10:35 PM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 12:59 PM
