Tone knob questions - Jemsite
post #1 of 5 (permalink) Old 05-13-2012, 12:14 PM Thread Starter
Tone knob questions
I have always been curious to see if a two pickup guitar could be wired to accommodate a volume knob and two tone knobs, and I know that this is fairly easy, but here is my question...
Of all the wiring diagrams I have seen, the volume will control the master volume of the guitar, and then you have a pickup specific tone knob. So one knob will control the bridge pickup, while the other controls the neck. I wanted to wire a guitar with two tone pots, one with a .047uf cap and the other a .022uf cap, but I wanted each knob to control both of the pickups, not a specific tone knob for each pickup. I was wondering if this is possible to do because I like to hear both of these capacitors on each pickup.
Please help,
Thank you
chef_ramseys is offline
post #2 of 5 (permalink) Old 05-13-2012, 12:35 PM
Re: Tone knob questions
Do you want both of them at once or one at a time? I'm not sure how both at once would sound. Probably a little odd. You can wire them separately and add a mini toggle that switches between two pots. Use one or the other. There is also a way to install a rotary switch to switch between several different tone caps on the same tone control. With this method it should be possible to even chain two caps together on one of the settings.
gideond is offline
post #3 of 5 (permalink) Old 05-13-2012, 12:52 PM Thread Starter
I wanted each separately. I was thinking a toggle switch would work but I am by far not an expert in this matter. Know where I could find a diagram for that kind of modification?? And the rotary switch could be cool as well, thanks
post #4 of 5 (permalink) Old 05-13-2012, 01:26 PM
http://www.premierguitar.com/Magazin...ctiveness.aspx
There is a little info on the rotary switch. I haven't ever found the need to wire one so I can only give you so much info on it.
As for the mini toggle, that should be relatively simple. You'd have a wire coming from the pickup selector to the tone pot normally. Instead of going to the tone pot you would connect it to the center lug on a mini toggle. Then the outside two lugs on that pole would each connect to separate tone pots where the lead from the selector would normally connect.
gideond is offline
post #5 of 5 (permalink) Old 05-13-2012, 03:03 PM Thread Starter
That makes sense. Thank you for the help
wiring
my tone knob is a volume knob... Homebake Pickups & wiring 12 06-27-2009 02:15 PM
tone knob?? wideopen98 Tech: Setup, Repairs and Mods 3 03-05-2004 04:56 PM
JS tone knob q? Reaper Pickups & wiring 1 09-01-2003 05:48 PM
tone knob viva Tech: Setup, Repairs and Mods 5 08-20-2003 10:09 AM
