Tone pots and switches - Jemsite
post #1 of 4 (permalink) Old 02-05-2005, 12:48 PM Thread Starter
I've got all the parts I need for my ibanez RG770 project except a swirtch. I'm considering getting a Dimarzio switch and maybe changing the tone pots. The body of the guitar is Basswood and the pickups im using are Evolutions, I don't know whether to get a 250, 500 or 1Meg pot?
I'm thinking a 1Meg would be too bright for these pickups??
clar-v-d is offline
post #2 of 4 (permalink) Old 02-05-2005, 06:40 PM
Re: Tone pots and switches
IMO 500k should work just fine!
Scott 74 is offline
post #3 of 4 (permalink) Old 02-05-2005, 08:48 PM
They would all work. A 250k tone pot would fatten up the evolution pickup a bit, but a 500K pot would be fine if you're unsure.
Btw, have you ever considered a Fender TBX Tone Control? It's a 250k/1Meg tone pot that acts as a 250k pot from 0 to about half-way(there's a notch in the middle indication full 250k) and then it dials into the 1Meg pot from there on. According to the guys at Fender, this tone control *supposedly* adds highs and lows to your sound. Mind you, this is for a strat so your mileage will vary on a humbucker.
buddroyce is offline
post #4 of 4 (permalink) Old 02-06-2005, 09:10 AM
Or you could get a push pull pot and switch a 470k resitor in parallel with a 500k pot to get (roughly) a 250k pot (242k actually) or you could take a 1M pot and put a 330k in parallel to get a 1M or 250k pot (248k.) Its an ok idea but it changes the taper of the pot slightly (IMO in a good way) also if you have a middle single you could actually use 250k pots with it!!
power freak is offline
meg pot
Blending Pots Instead of Switches? konfyouzd Pickups & wiring 7 08-27-2009 11:33 AM
Help - RG550 Replace pots and switches Oatman Tech: Setup, Repairs and Mods 2 06-23-2009 10:39 AM
switches and pots curiousity OneShot Pickups & wiring 0 03-19-2009 02:57 AM
replacing pups in rg550 should I change switches/pots, etc?? spindlergallery Pickups & wiring 8 08-28-2005 04:14 PM
Push pull pots or mini switches? stratman219 Pickups & wiring 5 09-03-2003 04:03 PM
