Tonezone Hum Problem - Jemsite
post #1 of 6 (permalink) Old 03-09-2012, 03:27 AM Thread Starter
I installed a tonezone in my rg320fm and it hums.Before i install the tonezone i had a seymour duncan and didn't have any issues with hum.I am sure i did the wiring correctly(i even solder an extra wire from the baseplate to ground).Any ideas?
ppanousos is offline
post #2 of 6 (permalink) Old 03-09-2012, 04:33 AM
Reviews: 120
Re: Tonezone Hum Problem
Did you connect red as the hot wire or black? Black is hot is for Seymour Duncan, red is for DiMarzio. Otherwise, check all your solder connections to make sure there are no cold solder joints.
LonePhantom is offline
post #3 of 6 (permalink) Old 03-09-2012, 04:34 AM Thread Starter
I did red hot,black and white together,green and bare to ground.
post #4 of 6 (permalink) Old 03-09-2012, 05:04 AM
Reviews: 120
Why did you solder an extra wire from the baseplate to ground though? I've never done that, don't have hum issues either.
Again check all your solder connections, there may be one that looks ok but isn't.
post #5 of 6 (permalink) Old 03-09-2012, 06:18 AM
Smile Re: Tonezone Hum Problem
Sounds Correct
sebastian is offline
post #6 of 6 (permalink) Old 03-09-2012, 11:01 AM Thread Starter
The hum stopped!I wired an extra wire from the baseplate to ground and i wired the green and bare seperately...
tonezone
Tonezone Problem Pooluke41 Pickups & wiring 2 03-11-2011 04:33 PM
Does this mean my ToneZone is bad? bhuether Pickups & wiring 2 02-27-2009 04:36 AM
Dimarizo Tonezone Sephiroth000 Gear, Equipment, Recording & Off Topic 41 06-04-2008 12:00 AM
FT Evo or Breed for Tonezone (uk) Dazza1004 Classified Ads: Guitars and Gear 3 06-22-2006 04:03 AM
Evo/ToneZone/Duncan/Other? NNS Pickups & wiring 13 06-17-2006 04:27 AM
