Tosin Abasi Custom wiring help - Jemsite
post #1 of 2 (permalink) Old 07-13-2013, 06:38 AM Thread Starter
Hi there
Attempting to wire up my RG2550 with the tosin_abasi_custom.pdf diagram from the Dimarzio site (sorry, cant post links yet).
The only difference I have is a Virtual 2 as my middle pickup and Im not 100% where I should be pointing the wiring from that as its 4 wire.
Cant find too many wiring diagrams for an EP1112 with a Push-pull tone pot and standard volume.
If I cant get something to work properly with this I can use the factory 5way as I have seen a few diagrams that will fit that - just seems a waste to have that lovely switch in the parts box.
Thanks for your time.
regards
Jason
UnbounD_NZ is offline
post #2 of 2 (permalink) Old 07-13-2013, 07:38 AM
Re: Tosin Abasi Custom wiring help
I'm going to be wiring my RGA8 with Ionizers the same way.
I have the diagram too.
You can just leave the pickup wired so there are only two wires to connect to the guitar.
Then ground to the pot back and hot to the switch where the diagram shows.
I'm guessing you have the VLX91 switch, it's needed to do this.
sebastian is offline
ep1112
Seeing Animals As Leaders!!! Tosin Abasi rules Bryancap77 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 7 03-22-2012 07:01 PM
Tosin Abasi custom hollow body Ibanez 8 string Putthecrossbetweenme&you All Other Guitars (including Prestige) 3 08-19-2010 08:33 AM
New Tosin Abasi/AnimalsAsLeaders Clip!! animalsasleaders Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 07-28-2009 07:33 PM
Custom 8 string from Tosin Abasi Brosa All Other Guitars (including Prestige) 15 04-14-2009 08:41 AM
Tosin Abasi playing his LACS 7 string animalsasleaders All Other Guitars (including Prestige) 6 12-18-2008 07:44 AM
