Using an on-on-on mini toggle as a 3-way switch - Jemsite
post #1 of 4 (permalink) Old 02-27-2011, 05:13 PM Thread Starter
Reviews: 7
I made a diagram of what I'm going to be doing, kind of crude sorry. The switching is between an 89 and an SA
Uploaded with ImageShack.us
The original diagram I modified had a ground running to the 3 way switch, should I just ground the casing of the mini switch or is it not needed? I've looked up a couple diagram's for using a mini switch as a 3-way and none said it had to be grounded. Thanks for any help
brothersnowgone is offline
post #2 of 4 (permalink) Old 02-27-2011, 05:58 PM
Reviews: 98
Re: Using an on-on-on mini toggle as a 3-way switch
Switches don't need to be grounded, as they are just the middle-men of the circuit--the circuit gets grounded.
AlaskaBat is offline
post #3 of 4 (permalink) Old 02-27-2011, 06:07 PM Thread Starter
Reviews: 7
That was pretty much my take on it. Thanks a lot for helping me confirm
post #4 of 4 (permalink) Old 02-27-2011, 06:33 PM
It usually gets grounded by being in contact with shielding foil or paint. It's good to have as many metal parts grounded as possible because they shield from noise. In this case, it probably doesn't make any difference
bancika is offline
mini , switch , toggle , wiring
SPDT mini toggle switches Death_Machine Pickups & wiring 1 08-06-2010 12:59 AM
Grounding a mini toggle brothersnowgone Pickups & wiring 5 01-09-2009 11:54 PM
3-way toggle switch question.. TMatt142 Pickups & wiring 0 11-30-2008 12:44 PM
Will mini toggle fit in pot's hole? toneboy Pickups & wiring 12 05-24-2006 07:46 PM
Using volume/mini-toggle push/pull pot as a pickup switcher? guitarkatana Pickups & wiring 2 01-26-2004 10:57 PM
