Using volume/mini-toggle push/pull pot as a pickup switcher? - Jemsite
post #1 of 3 (permalink) Old 01-24-2004, 09:36 AM Thread Starter
I'd like try this, since I never really use the middle position on a 3-way switch. It sounds like a cool idea to me, and I believe a lot of Caparison guitars use the same set-up. Anyone know how to properly wire this up?
guitarkatana is offline
post #2 of 3 (permalink) Old 01-26-2004, 03:57 AM
I would think that you connect the hot wire from each pickup to the outer lugs of one pole of the switch, and the wire to the volume knob to the centre lug. If I'm thinking right then you'd only need a SPDT on-on switch. A push/pull should be fine too - they're usually DPDT (far as I've seen), so just use one side.
dot-dot-dot is offline
post #3 of 3 (permalink) Old 01-26-2004, 10:57 PM Thread Starter
Thanks for the info.
I just bought a push/pull pot today, and before I could get it anywhere near the guitar it broke. What a piece of junk, and it cost like $8. For the time being I think I'll just stick with my regular setup of two hums, a vol pot and a 3-way. You know, stuff that doesn't break.
caparison guitars
Push/Pull *volume* pot on JS1000? smallbutmighty Ibanez JEM, UV, JS & Other Signature Models 6 06-30-2010 11:39 AM
2 wiring questions for push-pull and 2-way mini switch. IBNZ_RG Pickups & wiring 2 12-18-2009 03:53 PM
Push Pull volume pot EvoGiant Gear, Equipment, Recording & Off Topic 5 03-13-2009 11:34 PM
Push-pull coil tap or mini switches? shreddersymphony Tech: Setup, Repairs and Mods 16 02-07-2008 10:29 AM
Push pull pots or mini switches? stratman219 Pickups & wiring 5 09-03-2003 04:03 PM
