volume pot question - Jemsite
post #1 of 8 (permalink) Old 06-21-2012, 08:36 PM Thread Starter
volume pot question
I want to have a volume control separate for the neck and bridge pups on an RG520 without drilling more holes or adding more switches. I think I have it worked out by putting a stacked concentric pot in the tone pot hole,use the existing volume pot for the bridge and one of the stacked pots for volume , the other for tone all controlled by a three way lever switch. The easiest way to wire this,as for as I can see, is to wire the pups directly to the volume pots, to the selector switch and then to the tone pot. This will keep everything totally separate(afraid of back-feeding in other configurations) and will be accommodated by the three way switch. Is there any reason why I shouldn't run through the volume pots before the selector switch? Never done this before.
moonlight is offline
post #2 of 8 (permalink) Old 06-21-2012, 10:26 PM
Reviews: 98
Re: volume pot question
Nope--your idea should work just fine.
AlaskaBat is offline
post #3 of 8 (permalink) Old 06-22-2012, 02:17 AM Thread Starter
Thanks AlaskaBat. I've never seen guitar wiring like this so didn't want to do all the work and find out it was a fail for some reason. Those little electrons do some weird things sometimes. I feel much better about doing this now.
post #4 of 8 (permalink) Old 06-22-2012, 06:05 AM
So, you've never seen this:
xXLinkageXx is offline
post #5 of 8 (permalink) Old 06-22-2012, 06:36 AM
Reviews: 98
Similar, but the OP has a 3-way lever switch.
post #6 of 8 (permalink) Old 06-22-2012, 06:55 AM
woops, my bad. I changed it.
post #7 of 8 (permalink) Old 06-23-2012, 03:17 AM Thread Starter
Nope,never saw that before I drew it out on scratch paper the other day. Good to see a nice clean diagram though,thanks. Mine's a little different as I have a cts switch with eight lugs so i can coil split the neck pup with the switch in the center position.
post #8 of 8 (permalink) Old 06-23-2012, 03:28 AM
Reviews: 98
Go to the sticky thread at the top of this section--I've got tons of links in there to help out. That diagram came from one of the links there--there are tons more.
Volume Cap question. Cyrix Pickups & wiring 2 09-23-2007 06:08 AM
Jem volume pot replacement question HSH Tech: Setup, Repairs and Mods 3 08-10-2006 08:45 PM
Question about pickups/ volume pot flyingfinn Ibanez JEM, UV, JS & Other Signature Models 4 08-08-2005 03:41 PM
I've got a '02 jem7vsbl. question about volume pot. crank and spank Ibanez JEM, UV, JS & Other Signature Models 2 03-28-2005 11:37 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
