what 3-way switch to get? - Jemsite
post #1 of 7 (permalink) Old 01-29-2019, 09:34 PM Thread Starter
I have an RG7421 with the standard HH 5-way switching. I really like it, but having seen the switching capabilities on the AZ series i want to replicate it on my guitar. I want to install mini-switches for both pickups to get series/parallel/split and replace the 5-way switch with a normal 3-way. Anybody know the part number to get for the 3-way switch? I'll be ordering it from Rich.
adrianb is offline
post #2 of 7 (permalink) Old 01-29-2019, 11:42 PM
Re: what 3-way switch to get?
some of the newer ibanez guitars have switches like this one
https://guitarelectronics.com/3-way-...-lever-switch/
i like these a little better.
https://guitarelectronics.com/3-way-...h-oak-grigsby/
if you are after the az style, you should check out this switch instead.
https://www.stewmac.com/How-To/Onlin...tructions.html .
another alternative would be to give both pickups their own 5 way rotary switches and then use a 3 way lever switch to go between them.
j.arledge is offline
post #3 of 7 (permalink) Old 01-30-2019, 04:59 AM Thread Starter
link removed
Yeah i believe all Ibanez lever switches are "box-type" like that, rather than the original Fender kind with the exposed mechanism. If you know the Ibanez part number for that kind of switch i would be grateful. I'd rather stick to Ibanez and get it from Rich if he has it.
link removed
I've seen wiring diagrams that attempt to duplicate the AZ wiring and they look way too complicated for me. I feel i could get as many sounds with a simple 3-way plus a mini-switch for each pickup.
adrianb is offline
post #4 of 7 (permalink) Old 01-30-2019, 02:43 PM
to do series, parallel, split you'll need to find 3pdt on/on/on switches, not impossible but a little bit more expensive and more wiring than you probably want to do.
post #5 of 7 (permalink) Old 01-30-2019, 10:24 PM Thread Starter
Thanks for your insight, but that's really not how i want to do it. I want to install two on/on/on DPDTs, one for each humbucker, and ditch the 5-way for a standard 3-way (not a superswitch or megaswitch). That's what i need the standard 3-way switch for.
A closer comparison would be the dyna-mix 10 switching for the HH AZ models. You posted the dyna-mix 9 circuit. My version will get me all the dyna-mix 10 options except for the inner/outer coil split, which would need a separate phase switch. Powertap is probably just marketing-speak for parallel.
I will be removing the tone control so one DPDT goes in its place, and will be drilling another hole in between that and the volume knob for the second DPDT.
Does anybody know the part number for an Ibanez standard 3-way lever switch? Is it possibly 3PS1CGAE3?
adrianb is offline
post #6 of 7 (permalink) Old 01-31-2019, 10:57 PM
cool, I can't help you with the model number of the switch. I am going to work on a wiring diagram that gives you series/parallel/split coil. Hopefully i will get a chance to draw it tomorrow.
what pickups do you have in there ? stock, dimarzio, seymour ?
post #7 of 7 (permalink) Old 02-01-2019, 03:09 AM Thread Starter
You really don't need to bother with a wiring diagram. I've wired up my Strat this way. All i really need is the part number for the 3-way Ibanez switch. Thanks for the offer.
I'm hoping somebody knows and can give input.
adrianb is offline
ibanez rg7421 wiring mod
3 Way Switch vs 5 Way Switch Sean777 All Other Guitars (including Prestige) 6 07-23-2013 10:53 PM
Quesiton about corresponding ibanez 5 way switch diagrams for a fender 5 way switch GuitarEvan07 Tech: Setup, Repairs and Mods 0 06-19-2009 08:20 PM
Make a 5 way switch a kill switch? GuitarEvan07 Pickups & wiring 11 04-15-2009 02:19 AM
5 way switch, well err uh Switch. luvuvibanez Tech: Setup, Repairs and Mods 1 01-13-2009 11:52 AM
Hum-Hum, 3-way switch + Coil Tap Switch Wiring TAorama Pickups & wiring 1 06-19-2005 01:12 PM
