Wiring the ground to avoid hum? help - Jemsite
post #1 of 12 (permalink) Old 12-17-2012, 10:42 AM Thread Starter
Hope this chicken scratch pic i made up shows up. Made it just to get opinions cuz Im about ready to wire in my Motherbucker but didnt see any posts on actual Grounding info other than a few tidbits & this "ground loop" concept has always baffled me & i wanna avoid it at all costs.
Is it true that any time your ground wire connects to one point & then loops Back to another point,it can cause this hum effect? Im gona try running in a straight a line as I can with the basic grounding method and then the pickup grounds will go to the back of the pot (whcih will be grounded by the simple 1 wire run from trem to switch to vol to output).
2DECADESSOFAR is offline
post #2 of 12 (permalink) Old 12-17-2012, 10:44 AM Thread Starter
Re: Wiring the ground to avoid hum? help
sorry, the tiny print says "which pic will provide better grounding & less hum?"
post #3 of 12 (permalink) Old 12-17-2012, 12:05 PM
Reviews: 98
You've got it right!
Grounds go to the flat surface of the pot
AlaskaBat is offline
post #4 of 12 (permalink) Old 12-17-2012, 12:25 PM Thread Starter
But can the ground run from trem claw,swtch,vol pot,output jack be all one wire & the pickup grounds go to the back of the pot? or run ALL grounds to the back of pot?
post #5 of 12 (permalink) Old 12-17-2012, 12:41 PM
Reviews: 98
All grounds to back of pot.
Will be really hard to use one wire.
Run separate wires from trem claw--ground, etc.
post #6 of 12 (permalink) Old 12-17-2012, 01:08 PM Thread Starter
what I did on a guitar I had a few years ago,which I sold , I had 1 wire which started at the trem plate & rather than having a bare wire,I simply stripped just enough to bare the area where i would be soldering to & ran it to the switch & the pot & out to the jack. looking back it didnt seem to mater much in the quest for hum free operation. Im quite the low level solder-er
post #7 of 12 (permalink) Old 12-18-2012, 11:18 AM
All my older guitars are wired this way, but on newer guitars with VLX91 switches, Ibanez wires the ground to the switch.
I bring this up because one of my newer guitars with that switch has a hum issue. Anyone move the grounds on these switches over to the pot?
Takin' a Ride is offline
post #8 of 12 (permalink) Old 12-18-2012, 11:46 AM Thread Starter
What about the old Les Paul style metal plate? Kinda cool to not have Any wires to the back of the pot ,instead they all go to the metal plate which the switch & pots are mounted to.
post #9 of 12 (permalink) Old 12-18-2012, 01:58 PM
Reviews: 98
Yes--there should always be a ground to the switch to eliminate the hum.
I was referring to the pickups and claw.
The switch should be included in the ground loop, as you need to have every electronic component grounded.
Fixed bridge guitars usually have the ground going to a small plate, or a screw that's embedded in the body.
post #10 of 12 (permalink) Old 12-18-2012, 02:02 PM
Yeah I know that. What I'm saying is that on all my old guitars, the ground of the pickups always goes to the volume pot. On the newer guitar, the grounds from both humbuckers go to the switch. So they're relying on the switch for grounding.
I'm thinking about ditching the whole stupid VLX91 and just sticking a VLX53 in there, even though it's the "wrong" switch. It's totally standard switching anyway, so I'm getting absolutely zero benefit from the overly complex switch.
post #11 of 12 (permalink) Old 12-18-2012, 02:53 PM
Reviews: 98
I noticed that on a VLX91 switch, too. I just wired the grounds to the vol pot on one of my puzzletops when I did the new DiMarzio Steve Lukather pickups review.
post #12 of 12 (permalink) Old 12-18-2012, 05:08 PM Thread Starter
Im considering cuting out some sheet metal the shape of the cavity,like the old LPs & rather than solder (whihc has been the FAILED portion of every guitar project I take on , but rather than solder........just use short sheet metal scres & run all grounds to that sandwhiched under a fat textures steel washer,and ofcoarse the switch & pot would be grounded by the sheet metal. but ATLEAST i could use something Mechanical to use to ground with. I HATE soldering & can not successfully do it. Its a fine art that I suck at no matter how patient I am. Im always up for any ideas that requires less soldering.
hum hiss mod guitar
s1 single coil ground wiring help e32lover Pickups & wiring 7 07-23-2012 03:36 AM
Using PayPal to avoid USPS size limits? mpr Vendors, Auction & Reseller Talk 7 01-14-2012 10:10 PM
wiring / ground issue Bronx Pickups & wiring 5 12-16-2010 02:40 AM
Electrical Inteference - What can I get to avoid it? carlos seo Gear, Equipment, Recording & Off Topic 6 04-29-2002 11:56 AM
Shimming? - Common issue or something to avoid? Skarekrough Ibanez JEM, UV, JS & Other Signature Models 10 03-25-2002 05:35 AM
