wiring issue with 2 humbucker 1 single coil - Jemsite
post #1 of 8 (permalink) Old 07-14-2013, 07:09 AM Thread Starter
I bought a set of dragonfire pickups 2 phat humbuckers and a single coil and it came with instructions for wiring which i have followed twice to no avail.
green = hot
black and bare = ground
red and white soldered together = tape off (no idea why)
When i wire the 2 humbuckers up with no single coil it sounds great (although middle position in the switch is dead) as soon as i connect the single coil the 4th position on the switch (bridge and middle) becomes extremely weak. All other positions seem to be workin ok (not as powerful as before without the single coil) but working well all the same.
The guitar only has 2 pots volume and tone. i grounded 1 humbucker to each pot then i had to stick the 2 ground wires from the single coil on a random pot (im guessing its probably the same 1 as the bridge is attached to)
Any suggestions as to what i have done wrong that would cause something like this to happen? i thought ground wires all touched together in the end so it doesnt matter if they share a pot for grounding
dano1066 is offline
post #2 of 8 (permalink) Old 07-14-2013, 10:38 AM
Re: wiring issue with 2 humbucker 1 single coil
Try swapping the single coil wires around. It might be backwards and causing it to be out of phase with the humbuckers.
Mark_McQ is offline
post #3 of 8 (permalink) Old 07-14-2013, 10:51 AM
RGTFanatic's Avatar
I agree. I'm wondering why the single would have 2 grounds though. Is it a stacked hum?? I would also be sure that there is a ground connecting both pots.
can you upload a copy of the directions they sent you? I couldn't find them online.
RGTFanatic is offline
post #4 of 8 (permalink) Old 07-14-2013, 10:56 AM Thread Starter
right ill give that a try now. i got no diagram from the site just a text description.
"The green is hot and goes to the switch. black and bare are both grounds. red and white are soldered together and need to be taped off not to touch anything."
The next part confused me and could be what im doing wrong.
"bridge north start-green end-red
south start- black end- white
neck north start-black end -white
south start- green south end-red"
hopefully ye guys know what it means
EDIT:
I tried swapping the wires around. the black to the switch and green to the pot didnt work BUT i tried this with a humbucker and it made a sound when the ground was touching the switch and hot touching the pot?? also they all seem to work fine without the bare wire touching anything
dano1066 is offline
post #5 of 8 (permalink) Old 07-14-2013, 01:22 PM
RGTFanatic's Avatar
can you take pictures of each pup including the wires on each where they attach to the pups?
post #6 of 8 (permalink) Old 07-14-2013, 01:53 PM Thread Starter
Here is a picture of the single coil
nerdburglars.net/images/random/dan/2013-07-14%2018.53.54.jpg
The humbuckers are covered up with tape and this fabric stuff so i cant see the wiring for them
dano1066 is offline
post #7 of 8 (permalink) Old 07-15-2013, 05:47 PM Thread Starter
i finally got it sorted out. I completely unsoldered everything back to the way it was when i started. soldered the 2 humbuckers to the switch and the soldered the 2 ground wires to a single wire which i then soldered to the back of a pot then i chopped the bare wire off and covered it in tape and they work fine..should the bare have done something? i then messed with the single coil turns out ye were right swapping the wires around for the single coil worked it sounds great now. i also cut off the bare wire for the single coil too. could the bare wire have been causing this problem? i dunno if its bad that ive done this but i did and it sounds fine to me so it musnt have been importnat
dano1066 is offline
post #8 of 8 (permalink) Old 07-21-2013, 12:13 PM
Reviews: 98
The diagram is backwards.
I posted that in the sticky at the top of this section.....
AlaskaBat is offline
5 way switch , humbucker , single coil
FS/FT Single coil and humbucker Cameron1234 Classified Ads: Guitars and Gear 0 12-26-2012 05:04 AM
Wiring a Telecaster for Humbucker and single coil toma Pickups & wiring 11 07-17-2012 05:45 PM
Single coil tone from a humbucker scotte_za Gear, Equipment, Recording & Off Topic 21 09-28-2010 10:07 AM
WTB: Single Coil 6'r Neck Humbucker djpharoah Classified Ads: Guitars and Gear 1 10-22-2008 01:15 PM
Single coil sized humbucker? Dee Pickups & wiring 6 05-29-2006 12:16 PM
