wiring stacked coil without pots etc - Jemsite
post #1 of 5 (permalink) Old 06-22-2013, 07:20 AM Thread Starter
I'm a newbie keen to get into wiring but want to keep things simple to start with.
I've just got what I assume is an old Dimarzio stacked coil (marked IBZ USA, but no other code), which I plan to use as middle, in between Paf Pro and Breed humbuckers. It's 4 pole (with 2 wires currently taped off), with 2 coils separated by a plate.
What are my choices if I don't want to be adding pots / 7-way switches etc?
What I've worked out so far from wiring diagrams here and on Dimarzio site
Option 1: Basic setup without splitting anything (neck, neck+mid, mid, mid+bridge, bridge), so just wiring up the hot, black&whites joined and taped off etc.
Option 2: standard split humbucker set up (which seems to be the standard popular set up here?), which requires the stacked coil in single coil mode. I've got wiring diagrams for this looking at HS diagrams from Dimarzio site. This means adding a switch. I'd rather not do that at this stage.
Do I have other options with the pickups I have to keep things simple for this beginner?
Thanks
Pan99 is offline
post #2 of 5 (permalink) Old 06-22-2013, 08:25 AM Thread Starter
Re: wiring stacked coil without pots etc
To add, I'm also a bit confused about the splitting the stacked coil. I've assumed stacked HS wiring will be the same as that for my stacked coil(?).
The Dimarzio wiring diagram for 2 humbuckers and a middle HS (in single coil mode) says to just connect the black from the HS and ground the others. (sorry - forum won't let me add a link as to few postings). Diagram is for 2HB one HS (1 Volume, 1 Tone; Neck, Split Neck & Middle, Middle, Split Bridge & Middle, Bridge).
It says to ground all wires from stacked coil except black, meaning I don't need a pot? i.e. wiring like this will have it in single coil mode. Is that really right?
I've looked at the wiring for splitting an HS. Would I get much benefit adding the switch? would I use a stacked coil in both single coil and humbucker mode anyway with the other 2 HBs? Not sure how i would combine the two diagrams if so...
Sorry for the simple questions. Reading round a lot and finding my way
Pan99 is offline
post #3 of 5 (permalink) Old 06-22-2013, 11:02 AM
It's hard to help without knowing what guitar this is or which switch.
GodzillaPopcicle is offline
post #4 of 5 (permalink) Old 06-22-2013, 12:48 PM Thread Starter
Thanks, it's my first project guitar using a Jem7 neck. Have a few bodies I haven't decided on yet. I've hb Dimarzios for neck and bridge and the aforementioned stacked coil for bridge.
I've bought a standard 5 way selector (with the 8 connectors in a row). I've only recently found this site and learnt of the VLX91 - don't have that. But the Dimarzio wiring diagrams I reviewed suggested a standard selector should be ok.
No other switches yet.
Pan99 is offline
post #5 of 5 (permalink) Old 06-22-2013, 02:08 PM
Those standard diagrams don't know your parts or intentions.
You have a wide open door for many possibilities.
Decide what you want the pickup to do...then decide on the right switch.
Besides the VLX91--you can use any multipole "super switch" to provide many switching combos.
dimarzio , pickup , stacked
DiMarzio Stacked Single Coil - Made for Ibanez IBZUSA C2 djrjems Classified Ads: Guitars and Gear 1 02-10-2012 01:14 PM
FS: Paf Pro, Fred, Jem Single Coil, Jem Switch and Two 500k Pots wandereruk05 Classified Ads: Guitars and Gear 2 03-16-2011 09:52 AM
wiring pots jimistephen Tech: Setup, Repairs and Mods 5 02-26-2011 02:26 PM
wtb: dimarzio stacked single coil charv712 Classified Ads: Guitars and Gear 0 02-10-2011 12:39 PM
WTB: Neck Stacked Single Coil like Dimarzio Area 58 or Pro Track...etc. jumpinjackf1ash Classified Ads: Guitars and Gear 0 02-14-2010 02:39 PM
