Wiring up my guitar and have some questions... - Jemsite
post #1 of 12 (permalink) Old 11-17-2013, 08:38 PM Thread Starter
I'm sitting here with wires hanging ready to make this baby run and I had a few questions.
For one, the treble bleed on the volume pot. What would the characteristics be with and without it?
Also, how much pickup lead can I leave tucked away for a rainy day?
The guitar is all shielded in copper foil so shielding isn't an issue and the pickup wires are also obviously shielded as well...how much difference in maybe 4 extra inches of wire?
POS RG is offline
post #2 of 12 (permalink) Old 11-18-2013, 12:24 AM
Reviews: 6
Re: Wiring up my guitar and have some questions...
with a treble bleed you're high frequencies will not be rolled off as you roll down your volume knob.
I guess leaving the pickup cable full length has no impact on the sound, at least I haven't noticed a difference on my side.
satch_jr is offline
post #3 of 12 (permalink) Old 11-18-2013, 01:08 AM Thread Starter
Thanks. Good to know.
I'm using the evo2 pickup in the bridge and I want that nice shimmering clean tone when I roll back the volume.
I wired up the whole thing a little while ago with the treble bleed.
POS RG is offline
post #4 of 12 (permalink) Old 11-18-2013, 02:07 AM
Reviews: 6
I also have the EVO2 in bridge: lovely in all situations!!!
satch_jr is offline
post #5 of 12 (permalink) Old 11-18-2013, 07:23 AM
I think you have this backwards. The treble WILL be bled off as you roll down the volume, which is why it's called a treble bleed circuit.
If you don't cave the resistor there, as you roll down the volume, the guitar becomes very treble-y because the bass all rolls off but the treble does not. This was something that was mainly on Jems back in the day. RG's didn't have it.
As far as leaving the entire pickup lead, it just isn't really necessary. I leave enough so that there's plenty of slack to play with but never the entire lead. That's just too much wire laying around the cavity.
Takin' a Ride is offline
post #6 of 12 (permalink) Old 11-18-2013, 08:19 AM Thread Starter
i cut about 4 inches off my humbucker leads.
I have enough in there where if I ever sold the pickups or whatever, They could easily be installed with plenty to spare.
I installed the treble bleed and we'll see what it sounds like. If I dont like it, it's a simple nip to get rid of it.
POS RG is offline
post #7 of 12 (permalink) Old 11-19-2013, 04:02 AM
it is called a high pass cap and yes it allows the higher end to jump the lug to your ouput jack so you retain clarity when you roll the volume knob down.
j.arledge is offline
post #8 of 12 (permalink) Old 11-19-2013, 05:57 AM Thread Starter
Thank you.
Anyone find a particular rating other than the factory one they like and why?
Once this thing is up and running I plan on experimenting to tweak it. This will be my new main guitar.
I plan to play it a lot albeit only at home.
POS RG is offline
post #9 of 12 (permalink) Old 11-19-2013, 08:49 AM
Reviews: 6
That's what I though.
To POS RG, I do not have specific values, I only use a 330pF cap without resistor. It seems to be ok as I haven't searched any further. I do not play much with the volume excepted in clean sound or with crunch/slightly dirty sounds (which I'd like them to be on the fatter side than one the brighter one)
satch_jr is offline
post #10 of 12 (permalink) Old 11-19-2013, 10:33 AM Thread Starter
Thats the same one I used purported to be the spec Ibanez used.
I guess I'll see how she sounds once I get her all strung up.
Hopefully today or tomorrow.
POS RG is offline
post #11 of 12 (permalink) Old 11-20-2013, 01:44 AM
Wait it's a capacitor? My mistake. I thought it was a resistor this whole time.
Only Jems and other higher end guitars have that on the volume pot/
Every guitar I've seen has that capacitor on the tone pot.
post #12 of 12 (permalink) Old 11-20-2013, 06:03 AM Thread Starter
I have the same cap pictured above on my volume pot and I have an orange drop cap on my tone pot.
ratings are 330pf on volume, and 220mf on tone respectively.
I got both of them from allparts.
All resistors I've ever seen are cylindrical with colored bands around them for identification.
POS RG is offline
wiring questions (dimarzio) j.t..i. Pickups & wiring 3 11-06-2009 09:25 PM
EMG PU wiring diagram Questions Unit-2 Tech: Setup, Repairs and Mods 1 06-29-2009 12:21 AM
EMG PU wiring diagram Questions Unit-2 Pickups & wiring 0 06-13-2009 10:36 PM
A few wiring questions peter762033 Pickups & wiring 3 11-24-2008 04:16 PM
jem 7 wiring diagram questions Koss Pickups & wiring 0 09-08-2005 12:21 AM
