1 - 2 of 2 Posts
hey, iv got some new pick ups not sure about how to wire in 3 way lever import. 8 pin 3 way. 1m vol pot, 2x yjm furys seymour
so far I got it b.b.x.v.v.n.n.x, im getting sound but it doesn't sound all their. both green bare are to the vol
http://www.guitarelectronics.com/pr...uckers3-Way-Lever-Switch1-Volume0Tone000.html
They are hum cancelling so wired the same way, tape off red and white, then ground the green and bares to the volume pot.
Assuming you want standard full hum cancelling tones this should work perfectly by having full bridge, both pickups in middle, then full neck...
I would recommend getting a fender/oak switch as they are a little easier to work with than the modern styles...
Do you have a picture of your switch?
1 - 2 of 2 Posts
