These two scale patterns are major and minor scales starting with the tonic (C) on the 7th string, peaking with the tonic (C) on the 1st string, and covering 3 full octaves in the process. They are not 6-string major and minor scale patterns with the reachable key-related notes filled in on the 7th string.
Things to keep in mind:
- The major scale pattern ascends/descends in slightly different ways.
- In both scales, a "shift" will be needed on the 3rd string whenever there are 4 notes in a row. I would recommend using your 1st finger because it is the most accurate, but feel free to experiment.
The scales are written at the 1st fret because that keeps the tablature simple. Once memorized, they can be played anywhere on the fretboard. When used as relative major/minor scales (E Major - 5th fret, C# minor - 2nd fret), these two patterns cover nearly every note for both keys across the first 12 frets (and the last 12 frets).
If these scales are helpful, please use them.
