1 - 8 of 8 Posts
· Registered
when i get a 7-string in the future should i get a fixed bridge or a normal trem(music man petrucci) or floating (UV) i dont really see a point for a tremolo on a 7 string ... What do you think
· Registered
I have RG 1077 XL with a Lo Pro Edge 7 in it and I think it is great. In the end it all depends on if you are trem user (heavy or little) or not. Depending on that answer you should the 7 string based on that.
Regards
André
· Super Moderator
I try to look at guitars as tools. If you can, you should have one each trem and non-trem. If you know what you want to play on it, then you've pretty much narrowed it down. If you don't, I'd get a trem and maybe a tremel-no and block it when you didn't need it. My main 7 has a trem, as all of my non-hollow body main rock guitars do. I don't go nuts on the trem with divebombs though, as they don't really fit what I play too often. So, I guess if you can only have one I'd say get a good trem and something to block it when you don't need it.
· Registered
As far as i can see the Petrucci isn't really a normal trem. I think it's recessed and you could basically use it as a Floyd trem (though probably not as effective mabye because of the tunning).
I'd go with the Petrucci and put a piezo in :p
· Registered
Yeah, the Petrucci trem is fully floating with a recessed cavity, but there's nowhere near as much pull-up range as a fully recessed Floyd. It has locking tuners so, with a proper setup, it should stay in tune reasonably well under light to moderate trem use.
1 - 8 of 8 Posts
