Use Zakk Wylde's GHS Boomers which use .70s as a low E I believe on a 6. I can't go for the mismatched tensions, but I have usd .13-.58s in the past on a 6.ChopTart said:WOW... 70? you must have some toned fingers![]()
I must be the only person that uses those in B, I prefer super thick strings for my 7. I usually just buy an extra .10 to make them a 7 set, real meatyred5 said:Use Zakk Wylde's GHS Boomers which use .70s as a low E I believe on a 6. I can't go for the mismatched tensions, but I have usd .13-.58s in the past on a 6.
This is tuned to A mind you, although I'd still use 60-65 if i tuned it to B as i found the low string really benefits from that extra tension. I then use a 10-52 (or9-46 if in standard) set7 Dying Trees said:a .70 will fit. You may need to drill out the tuning peg though, as I've had problems fitting the string through in one or two of my guitars.
Hey whatever works for you. Just to confuse people I am going to use all .20s. Probably have to tune it like a sitar or something else.brothersnowgone said:I must be the only person that uses those in B, I prefer super thick strings for my 7. I usually just buy an extra .10 to make them a 7 set, real meaty![]()
red5 said:When I had 13-58s, people would ask "can I play your guitar?" I'd tell them "you can try if you want!" and they'd try to play a chord, fail and give it back![]()
But I am talking about on a 6!rgk7 said:yeahthats right I´ve heard this so often!Ha!
The only guy who was able to play it like that was my drummer...I asked him if he was sure for going with drums![]()
