Hi all
I've been reading up about Bore oil and have decided it is definitely the way to go for treating a rosewood fingerboard. However, this has lead me to a few new points to consider:
1. Up until now I have been using Pure Raw Linseed Oil. Now that I will be using Bore Oil, should I think about trying to get rid of any Linseed Oil left in the neck? If so, what is the best way of doing it?
2. I know a lot of people speak very highly about Fret Doctor from Beafifer. But others seem to think there is little difference between this and much cheaper Bore Oil (Le Blanc, Selmar, etc.). Any views on this would be great.
3. I have a guitar with a maple neck. It is usually said that these only need treatment once the lacquer coat has worn off. My fretboard definitely has a worn look, but I don't know if it is bad enough to warrant treatment. I'm only interested in treating it from a preservation/maintenance point of view - NOT cosmetic. In fact, I'm quite keen on the worn look! I can't post links to pics until I have 20+ posts.....so I will add pics then.
Any advice would be really great.
Cheers
Max
Cheers
Max
