1 - 7 of 7 Posts
I've got this Ibanez RG guitar body copy, and it has a AANJ, but I'm not sure if its the same as a real Ibanez, does anyone know how far the screws are apart? Maybe a diagram would be cool. Thanks!
That's not an RG, it appears to be an EX350 body model year 1993 most likely.
And to answer your question, yes it's a real Ibanez however an RG neck will not fit it. The AANJ EX guitars have a fairly different bolt pattern and only an AANJ EX neck will fit. They pop up on the 'Bay every now and again.
Discussion Starter · #5 ·
Ok, well its not mine, I was just taking measurements off it for my guitar build. Thanks! I was wondering if it had a different bolt-on pattern.
The pattern looks close, but you can't be sure.
If you are starting a body from scratch then there are a couple of things that you can do. You could try dabbing a little chalk dust around the neck holes and pressing the heel into the neck cavity to mark the new hole. You could just drill new hole sin the body and plug and redrill the neck holes.
1 - 7 of 7 Posts
