I have just installed a push/pull volume switch into my RG for coil splitting. I wired them according to the diagram found in the tech section of Jemsite.
I know that when the switch is turned on (pulled), the humbucker is splitted.
How about position 2 & 4? Which coils are functioning when the switch is on?
Isn't that , even when the switch is turned off (pushed), at position 2 & 4, the function coil is the middle single coil and the inner coil of the humbucker? But I did hear the sound changed when I pulled the swicth at position 2 or 4. Which coils are functioning when the switch is on at position 2 or 4?
BTW, after installing the switch, it seems that at position 4 (bridge+middle),it sounds brighter than before (ToneZone+HS-2) while it sounds the same as b4 at position 2 (Humbucker from Hell + HS-2)
Is this normal?
Is this normal?
