1 - 17 of 17 Posts
· Registered
Basically, my friend has an RG7321 (I think that's it, although it has white binding on the neck, a fixed bridge and a 5piece Maple/Bubinga neck - without scarf joint). It's pretty bashed up and has 2 green DiMarzio Blaze pickups.
I was going to buy DiMarzio Blazes anyway for my other 7-string, but i figured if i got his guitar for say £200-250 i could swap the pickups and keep the other guitar for messing around with (Tune to G or something silly).
Blazes cost around £150 (at a guess) so really, i'm buying a guitar for £100odd.
Would you guys think this is a good idea. Should i put the extra £100 towards getting another guitar to mess around with seening as i already want those pickups? :p
· Registered
I have a RG7321 and think for the money if can't be beat!! It even sounds pretty good with the stock AH7 pickups so I say go for it, plus it might give you a different feel and sound to your other guitar which you might enjoy! with the pickups out of your other & in it you'l probably end up with 2 great sounding axes!!
· Registered
Discussion Starter · #6 ·
If i did this deal, i'd probably strip the body and put in some EMG 7-HZ pickups i found around (only reason i wouldn't put this in my other 7 is because of the extra routing - which i don't really want to do to my fravorite guitar! :p).
That means a real Bad Horsie ;)
1 - 17 of 17 Posts
