b5 is the same thing as #4 or #11 and theyre all called tritones.
a tritone substitution, very basically, is where you substitute a tritone from the bass note for the actual bass note ONLY IN DOMINANT 7th CHORDS (not maj 7, min 7, etc.). For example...you have a C7 chord, if you want to tritone sub it youd replace the C with an F# creating the chord F# E G Bb, which gives you a b9 which creates considerable tension.
where this gets interesting and useful is in chord progressions. since you said youre gettin into jazz, then you should know the most common chord progression in jazz is the ii-V-I which means you have a minor 7 going to a dom 7 going to a major 7 (half dim 7, dom 7, minor 7 if youre in minor). If we stay in C, this prgression would be Dm7-G7-CM7. However, if you tritone sub the G7 (remember, only dominant chords can be subbed) then you replace the G with C#/Db. your progression now is Dm7-C#/Db7-CM7 which gives you a chromatically descending bass motion with considerable tension in the dominant (which is what theyre designed to do, but with the tritone sub you add outside notes from the scale like the b9 (C#/Db) which gives the listener a sense of, "whoa, something happened." Then when the dom7 chord resolves to the M7 then the resolution is enhanced.
Since most players add extensions to their dominant (and other) chords like the altered (raised or lowered) 9, altered 11, or altered 13 depending on the motion, tritone subs can change a chord to give the progression more color. if you tritone sub a C 13 (C E Bb A - most important notes) you end up with F# E Bb A which is a F#7(#9) more commonly known as the Hendrix chord. so theres some interesting things to be done with tritone subs.
in summary, the tritone sub is used commonly to create tension within common ii-V-I chord progressions and to create a chromatically descending bassline. The tritone, changes the dominant chord and adds extensions within the scale that enhance tension-release. tritone subs only work on Dominant 7th chords because the dominant chords are harmonic devices to strengthen the key center, and by adding more tension, the resolution is enhanced. tritone subbing a M7 or m7 would only lead to confusion as to what the actual key center is.
hope this helped. if anything is unclear ill clean it up.
