1 - 17 of 17 Posts
yes the wizard 2 is noticably thicker, than the original wizard.
if you want a hell of a lot better quality i would go with a used 570 or up . The 760 would be way better quality, just make sure you know the fret condition, and that the neck doesn't have any cracks.
Well, I have guitars with all kind of necks (pau ferro with purple heart stripes, bocote with cocobolo stripes, katalox with maple stripes, bird eye maple with walnut stripes, 3 piece maple, one piece maple, etc, etc). All I can tell you is that the shape of the neck and the kind of finish you have on it are the thing that will determine how comfortable you feel with it. The woods and typ of construction you use will have more of an effect on things like sustain and the reliability/durability of the neck.
So far this is my favourtite neck:
http://photobucket.com/albums/v493/RCB/customs/?action=view&current=ARBMcustom5.jpg
Its a katalox/maple/katalox/maple neck with a figured cocobolo headstock. The neck is sanded for a raw feel but the headstock was left with a polished finish.
These 2 necks are the closest contenders:
http://photobucket.com/albums/v493/RCB/S custom/?action=view&current=S2.jpg
The one with bird eye maple with 2 striples of walnut
An finally the pau ferro with the striples of purple heart (although this neck is a little thicker than the others):
http://photobucket.com/albums/v493/RCB/PGM finished/?action=view&current=pgm30.jpg
Jemwielder said:
RCB, i'm assuming none of those are stock ibanez guitars? Either way they're amazing
You are right. They were custom made. But I wanted to show other options rather than maple or mahogany wich are the most classic alternatives.
Thanks for your comments anyway!
Brines said:
Which wood is the best for necks? What's the difference between a RG470 and an RG470DX? Do any RG570s come with sharktooth inlays? Also, is it possible to add a pickguard to 570s or 760s?
best wood to me still maple w/ rosewood fingerboard.
RG 470 and 470 DX? I've never seen any 470 Dx in my catalogue, but I assume the DX comes with sharktooth inlay, neck binding.
RG 570 once comes with sharktooth, the 2000-1 RG 570 EX, comes with cyber pink or blue finish.
yes, it's possible to add a pickguard, but why bother? it's better you get RG 550 rather than modify your 570.
zEr0 said:
Where does that come from?! It looks gorgeous.... :)
thnx ZErO, it's on my Jem90HAM.
@RCB I agree that the finish and shape are major factor in determining the feel of a neck, but don't rule out the woods. First of all the fretboard wood, but in case you have a thin finish an oil finish or even no finish on the back of the neck, that wood is also going to make big difference. As you mention yourself, sanding the neck is an option.
I must add they look great, did you specify those woods when you went for a custom, or did the luthier recommend them? Were they picked for sound, looks or durability?
Super Moderator
Personally I like maple necks with ebony boards. I also like mahogany necks, but ebony is definitely my favorite fingerboard wood. I have no real preference between maple and vaqnilla rosewood, but I like to have at least one or two maple boarded guitars lying around. Brazilian Rosewood is as nice to play as ebony to me due to it's feel, and there are some other woods that are also smooth and glassy that are up there with ebony, also. But basically, maple/ebony works for me.
I picked up the woods and the way they should be assembled (most of them 5 piece necks, one 3 piece neck, and a couple of them with diffferent wood on the tilted headstock) after a little research over the internet. I didnt actually build them though.
I was lucky enough to get to choose the exact piece of wood for every single part of those guitars (from the freatboard blanks to the tops and necks).
The goal was to make them play good and look good. The sound was a bit of a gamble. At the end of all things, out of the 5 customs that were made, I found that 2 of them are my prefered guitars, 2 others are on the same level as my other high end guitars (mostly Ibanez) and only one of them had several issues I wasnt happy about (although its still looks great).
I chose to have the necks cleared and sanded, mostly because I feel its a more durable option. I also experimented with slightly different neck shapes.
Oddly enough, I think the only guitar I ve ever had with a mahogany neck was an early 90s Gibson Les Paul (one of the best sounding guitars Ive ever played BTW).
1 - 17 of 17 Posts
