1 - 8 of 8 Posts
So I've finally got all of the parts I need to finish my RG550 project. The pickups I got are as follows:
Tone Zone- Bridge
Blue Velvet (NOT reverse polarity)- Middle
Humbucker From Hell- Neck
The problem is in the lack of reverse polarity in the Blue Velvet. I forgot to ask for that option when I was ordering the pickups at Guit. Cntr. Does anyone know if I can still use the non reversed polarity single coil and have everything work out? I assume the reverse winding of the middle pickup is for hum-cancelling purposes. Should I return it for a reverse polarity model or can I just go on without it? If I do go on without it, how do I do the wiring? I'm going by the JEM wiring diagram on the DiMarzio web site. I emailed DiMarzio tech support but it'll take a while for them to get back to me so I figured I'd ask around here first.
Thanks
I think you can still use it. When you split the humbuckers, you can use the outside coils instead of the inside ones in positions 2 & 4. The reverse polarity middle coil is a lot more important on Strats where you have 3 single coils.
or, if you still want to use the inner coils and have them hum cancel, flip the humbuckers 180 degrees. this will rotate the magents and in effect flip the magnetic polarities of the coils that are "inner" or "outer".
you may have to futz with the wiring to make sure you get the right wiring direction [to compensate for the fact that you don't have a Reverse Wound single], but with 4 conductor humbuckers it is possible to set it up this way.
The bridge coil that's closest to the middle pup is the best one to split to IME, because the output is higher. It just always seems to quack more.
Which neck coil is used with this seems to matter much less, so you can take your pick there.
So I'd want a south magnet there. If that has magnet polepieces, you COULD flip the mags around and wire it backwards. But if you can return it, that's a better bet.
not really, unless you have a humbucker of unusal design with two very different coils, the output of each coil is going to be pretty much the same.
the inner coil does quack more, but that's because of the position of the coil, toward the middle and farther away from the bridge. just like the difference between a bridge pickup sound and a neck pickup, the outer coil of a bridge humbucker will sound sharper and the inner coil will be smoother with more quack.
it may be more subtle, but you can hear a definate difference in the two neck coils as well. i like them all, so i wire all my guitars to use the inner and outer coils in different switch positions.
Well, that's what "in my experience" means. YES, my Duncan JB is like this, and it isn't an "uneven" design. (My Steve's special certainly does too, but it IS an uneven design). With the JB, I'm not sure if the extra output is due to that coil using slugs instead of screws, or if it's because the "inner" coil is 50% further from the bridge and thus senses more string excursion (the same way a neck pup has more output, but to a much lesser degree).
Yeah. In mine it's very subtle. I didn't say it didn't matter, only that it mattered less; at this point many people have other priorities like keeping combinations humbucking, so you choose the coil you have to for other reasons. If you want ALL the different sounds you'll have pretty complicated switching. I feel your pain, since I'm assembling my baby right now with 2 5-way switches and a push-pull pot! But that's more than most people want...
I can wire it pretty quick and easy to alternate coils. I'll usually have a push/pull that cuts them, and then another, or a mini toggle that "flips" them just by switching the coil cut ground to the respective hot on the switch. I agree with Jester about the output difference being from the string movement. The quack factor is individual. A strat bridge pickup angles from near the neck side on the low E to the bridge side on the high E, so it's kind of like saying "which string section are you trying to emulate the strat sound from, low or high?"
On the neck pickup, I find it to be essential which coil you use. Perhaps on a 24 fret guitar it's less apparent because you're already an inch or so back from where a strat neck pickup is. But if you're using the neck pickup as a single by itself, the throaty, greasy sound is only coming off the neck side coil, merely due to its location. As far as the combination with the middle pickup, though, both are okay, because that middle pickup addition notches (or quacks) out those freq's anyway. So you're back to personal preference there.
Well, that's what "in my experience" means. YES, my Duncan JB is like this, and it isn't an "uneven" design. (My Steve's special certainly does too, but it IS an uneven design). With the JB, I'm not sure if the extra output is due to that coil using slugs instead of screws, or if it's because the "inner" coil is 50% further from the bridge and thus senses more string excursion.
sure, any coil farther from the bridge will have slightly higher induced current in the windings because of the greater amplitude in the string motion, if all other things [like the number of windings] are equal. but the difference in amplitude for a half-inch of distance is small; hence "pretty much the same."
my point was that the output of the different coils is far less important for how the cut coils sound than their position. the same string amplitude issue changes the tone as you move from bridge to neck far more than it changes the output [especially given that neck pickups compensate with fewer windings]. you can't get as good a sharp bridge single coil sound out of the inner coil of a bridge HB because it's too far from the bridge, not because of the output difference. and like frank said, you can't get as good a phat neck single coil sound out of the inner coil of a neck HB.
1 - 8 of 8 Posts
