1 - 5 of 5 Posts
Hi all!
I have had my s970 for quite a while now and finally decided to make take the plunge and get a wireless system. I went with the boss wl20.. So initially, obviously, it wouldn't fit in to the recessed jack on my sabre, but a rubber washer to hold it further out solved that.
Now I have done that the wireless system engages and connects but I get no signal. I can slowly pull the transmitter out of the jack so it is *just* engaging and I get a signal (although distorted and intermittent). This made me think that the jack might be wired wrong maybe the hot to the wrong lug?
I cant find any decent diagrams explaining which lug is which...
has anyone had an issue like this before? Does anyone know how to fix it?
I already tried swapping the hot wire and even tried swapping ground and hot. but no luck. I havent tried bridging the shorter lugs..
Thanks!
Meganaut
Discussion Starter · #5 ·
Yeah I have tried and it works with all of my other guitars (including active pup models). the only different with the s970 I can see is that the jack is stereo where as my other passive pup guitars have simpler mono jacks
1 - 5 of 5 Posts
