I keep snapping the high E string on my bridge. I don't know what bridge it is but you can't tell from the image I uploaded because that doesn't work.
Although I uploaded an image of the saddle, it was apparently removed.
But from ibanez dot fandom dot com/wiki/Edge_Pro?file=Ibanez_Edge_Pro.jpg this image, it seems to be EdgePro (see www dot jemsite dot
com/forums/attachment.php?attachmentid=9797&stc=1&d=1533232611 ). It seems to swivel. Does it swivel? It's RG8670.
It looks like it might have a small pit, causing the string to get cut. How can I fix this? Can I replace the saddle? Should I try to sandpaper it?
Thank you!
Thank you!
