1 - 6 of 6 Posts
Discussion Starter #1
Hey there, I wasn't sure if I should post this in the tech section or not...
but if I wiggle the cable while it's plugged in my guitar, and the connection to the amp is kinda shaky, is that a problem with the electronics of my guitar or with the cable?
-Jeff.
If you wiggle the connector at your guitar and hear the problem, then it's a connector. If you wiggle just the cable and it exhibits the problem, it's the cable.
Put the same cable into a different guitar, and wiggle it. I would put my money on saying that it is the guitar, not the cable.
...or put another cable into the same guitar :wink:
Seriously, I've encountered this on many cheaper output jacks, one of them being on my otherwise trusty Blazer guitar, grrr.
If you really got a 270, like your username says, remove the output jack plate and look if anything is loose in there.
Discussion Starter #5
this is actually on an older jem...
should I take it in and have someone look at it or is something easily repaired with a soldering iron?
(the rg270 was my first guitar, way back when I made this userid :))
-J
Ahh, ok!
Sounds like the problem is not too serious. When you wiggle the cable, is the connection to the amp really interrupted or is there just a crackling noise?
Anyway, here's what I'd do:
Remove the backplate behind the output jack, wiggle around inside the cavity to see if anything is loose/moving, maybe stick a cable into the jack and wiggle it around to see what's happening 'inside'. Maybe theres a loose cable (yes, anyone with a soldering iron should be able to fix this; but if you're insecure, practise on scrap cables for a few minutes).
If everything is tight, check for dirt/greasy stuff on the contacts of the output jack and clean it off.
Oh, and be sure to try another cable first :wink:
1 - 6 of 6 Posts
