1 - 7 of 7 Posts
The Edge Zero has two springs on the back, and it's not possible to add/remove springs. One can only adjust the springs back and forth. Obviously, it's way less flexible than add/remove springs.
So I ask: would the Edge Zero have enough room to adjust to a .007 gauge? (Yes it exists, and I use it.) Or, if not that extreme, would the Edge Zero handle a .008 set? Anyone tried that?
Thanks in advance.
I'm ~99% sure the Edge Zero uses standard sized springs so you could replace the 2 springs with some lower tension ones. I know that plenty of people have done the opposite and bought higher tension ones so they could use .011 gauge and up.
My Edge Zero handled .008's fine when tuned to standard without having to change the springs, I've never used .007's on it though.
Hope this helps :)
Discussion Starter · #3 ·
Thanks for the input. Let me as another question then: with those .008's, did you still have room to adjust further? Or it was somewhat "on the limit"?
There was a little bit of room, but really not much. It worked fine for me in standard tuning but I wouldn't have expected it to work tuned half or a full step down.
Discussion Starter · #5 ·
So I bet they made the thing to hold .008's at standard tuning, maybe a half step down, nothing beyond.
Thanks man.
Hey there,
Just an update on this: I removed my Edge Zero yesterday when I was doing some restringing/setting up and when I removed the springs I realised they're not standard springs, they're a bit shorter than standard ones, so I don't think you'd be able to get .007's on there with them.
I've got .009's on there now and there's loads of adjustment room left though.
You always have the option of using heavier guage strings on the E, A, and D to compensate for the lower tension on the G, B, and hE.
1 - 7 of 7 Posts
