No locking nut problem, just want faster string changes and nothing beats locking tuners for this. I have a set of 6 inline Sperzels, thought I could actually put them to use now...
where do you personally cut the non-ball end to eliminate crazy wrapping?Kontalonis said:Do you string your guitar backwards (as in the ball end hits the tuner), this eliminates the need for locking tuners and lets you change strings faster.
You don't...you put the ballend in the peg....and run the castrated end thru into the bridge saddle...magenta placenta said:where do you personally cut the non-ball end to eliminate crazy wrapping?
:lol:darren wilson said:Zero to 360° in only 10 posts!
about two inches past the saddlemagenta placenta said:where do you personally cut the non-ball end to eliminate crazy wrapping?
I usually cut the high E and B about 3" past the saddle and the G about 2.5". I end up with about 6 wraps on the E, 5 on the B and 4 on the G tuning posts. When I break a string at the saddle during practice, I just loosen the locking nut, unwind the string, re-clamp the new end in the saddle and tune back to pitch. This method allows me to avoid changing a string and my guitar is back in service in less than a minute or 2.marianozz said:about two inches past the saddle![]()
hmm.... you may be on to somethingScreamJem7 said:I usually cut the high E and B about 3" past the saddle and the G about 2.5". I end up with about 6 wraps on the E, 5 on the B and 4 on the G tuning posts. When I break a string at the saddle during practice, I just loosen the locking nut, unwind the string, re-clamp the new end in the saddle and tune back to pitch. This method allows me to avoid changing a string and my guitar is back in service in less than a minute or 2.
They are entirely and more than that, why would anyone use Sperzel locking tuners? They slip and they break a lot. Get Schallers.Kamikaze_1 said:If you don't mind me saying this but...aren't Sperzels quite useless on guitars with a locking tremolo?
If you're cutting the strings that far beyond the saddle and getting 4 or 5 wraps around the post, then what's the point in doing the reverse stringing? You can do exactly the same thing by cutting off the ball end and leaving yourself a couple of inches of slack before you wind the string onto the post. I tried reverse stringing once, and it chewed up the finish on my tuners. Never again.ScreamJem7 said:I usually cut the high E and B about 3" past the saddle and the G about 2.5". I end up with about 6 wraps on the E, 5 on the B and 4 on the G tuning posts. When I break a string at the saddle during practice, I just loosen the locking nut, unwind the string, re-clamp the new end in the saddle and tune back to pitch. This method allows me to avoid changing a string and my guitar is back in service in less than a minute or 2.
