1 - 3 of 3 Posts
Discussion Starter #1
So I'm pretty excited to try this. I recently picked up an RG7620VK & am doing a number of mods to it. One of which is color matching the headstock. At first, I was gonna go to Sherwin Williams and get a color-matched rattle can for about $50. Then, my touch-up nail polish showed up, which is an out-of production Revlon color called Crimson. I originally got it to do touch-ups on the body but it is SO CLOSE to the VK color, and I mean.... identical, that I wanted to find a way to just use it to paint the headstock.
Mind you, the edge of the headstock is messed up & needs to be refinished anyway, so I figured this would be the perfect opportunity to try this. So last night, I ordered a cheap $50 airbrush kit off Amazon.
My plan is:
-Remove Neck, Hardware from Headstock
-Lightly sand existing headstock finish
-Shoot a rattle can primer on the headstock, sanding smooth
-Mix fingernail polish with acetone to thin it out
-Spray a light, wide pattern until headstock has a nice, uniform coat
-Mix some Revlon clear coat w/ acetone, apply clear coat
-Sand and buff if necessary
Please note, I have never airbrushed before, but consider myself somewhat of a rattle can master. For those of you that have airbrushed, does this all sound right? Thanks!
Sounds like a cool idea, I have no idea if it will work though. looking forward to hearing your results.
As a caution- A lot of those nail polishes are acrylic enamels...... test first to be sure it's compatible with your primer.
1 - 3 of 3 Posts
