1 - 6 of 6 Posts
Ther is a problem with my crybaby. Everytime i turn it on the pedal doesn't seem to work. I mean i don-t think its the battery, but evert time i step on it it doesn't do the effect. Can anyone help me?
Sounds like the battery to me. Did you jiggle the wires that connect to the battery? Also, have you tried pushing the on/off switch by hand several million times in a row? I actually had the massively industrial switch break on my Crybaby. Shocking, I know!
another problem i've had with several Crybaby's is that the plastic cog that actuates the wah can come loose from the shaft of the pot.
you might want to check that.
Discussion Starter · #5 ·
well it wasn't the cog. it was the bettery! i the cable were loose. I put the AC adaptor and it worked perfectly. But thanks anyways.
1 - 6 of 6 Posts
