I'm thinking about purchasing a new amp, and i'm between these ones, so I just would like to know your opinion and what should I pay attention in the characteristics of these kind of amps.
Peavey Classic® 30/112
Features:
• 30 watts (rms) into 16 or 8 ohms
• Four EL84s and three 12AX7s
• 12 inch Blue Marvel® speaker
• 2-channel preamp
• Pre- and post-gain controls on lead channel
• Normal volume control on clean channel
• 3-band passive EQ (bass, middle, treble)
• Boost switch
• Reverb level control
• Effects loop
• Footswitch selectable channel switching and reverb
• External speaker capability
• Chrome-plated chassis
• Classic tweed covering
Fender Hot Rod Deluxe™
Features:
• 40 watts
• 1 x 12" 8 Ohm Fender Special Design Eminence speaker
• 18.75" H x 23.5" W x 10.5" D
• 45 lbs.
All Hot Rod Deluxe and Hot Rod Deville amps feature:
• Three selectable channels (Normal, Drive and More Drive)
• Gain and Master controls in Drive channel
• Bright switch in Normal channel
• FX loop
• Fender long spring Reverb
• Two 6L6 Groove Tube output tubes
• Three 12AX7 preamp tubes
• External speaker jack
• Two-button Three-function footswitch for Channel select, Drive/More Drive select
• Chrome panel with vintage pointer knobs
• Internal Variable Bias control
• Black textured vinyl with silver grille cloth
• Cover included
What do you think?
Thanks!
Features:
• 2-channel preamp
• Boost switch
• Effects loop
Features:
• 40 watts
• 45 lbs.
• FX loop
• Cover included
What do you think?
Thanks!
