1 - 10 of 10 Posts
As the community proven itself to be extremely helpful, I've decided to come here with my another issue. I have quite old Zoom G7 which I bought used. It worked fine for a first few months, but then it started to have problems when turning on. It was getting more and more irritating to the point it won't boot anymore. I've written a quite comprehensive summary of the problem, that I am going to mail to any Zoom support on earth I can find.
Perhaps someone was able to solve such problems?
Current state:
  • Normal booting (just turning up):
    The screen is backlit, the tube glows and the unit is recognized as USB soundcard
  • Factory reset mode (Store/Swap pressed)
    Behaves same as above
  • Check(maintenance?) mode (Exit + System pressed when turning up)
    Everything works, except clicking "Page" button shows PAGE at the top (I figured it's a correct behaviour).
    The second line of the screen states "Flash Write Err", and the LCD has "nG" letters.
  • Firmware update mode (System + Store/Swap)
    When prompted, it tries to send or receive patches from another zoom (my MIDI cable lights up).
    Software updater version 1.06 is able to see it ("RomSys Revision 9031").
    When I click "Execute", it changes to "Saving your patches...error".
    I was kinda hopeless and trying to get it as far as I can, so I've decompiled the updater to C# code,
    And set a breakpoint on the patch saving function. It did fail indeed (no proper response from the device,
    I think). I commented it out (I don't care about the patches, obviously), and the next function was promising
    ClearChip. When it was issued, the G7 screen showed "erase error" on the bottom line. I couldn't get any further.
    I have also noticed that when booted, the LEDs next to big metal switches flash very quickly (as it was constantly rebooting,
    perhaps), and the device is sending something via midi constantly (my cable flashes).
  • Additional info
    The service mode reports on A button :
    G7 V1.01 R9031
    CRC : 3D78B445
    And on B button :
    G7F V1.061.056 R
    CRC : AB61BFC7
I kind of realize that this might be a lost cause, but I want to try everything I can first.
Have you accidentally plugged the incorrect voltage and/or polarity power supply in to the unit? Chances are one or more of the chips on board are fried. That would be my guess. :(
I would check with Zoom to see if they can suggest an authorized repair center in your area.
Jimmy:smile:
Discussion Starter · #4 ·
I have contacted Zoom support, and the guy there was really nice. He said he will try to estimate the cost of repairs, before I send it to them. I might be better off with just a new unit.
I had to reload the firmware on my G7.1ut continuously about thirty times. I also downloaded the firmware update each time. It fixed my restarting problem.
Sorry for raising the thread from the dead, but..
I also have a problem with my pedal and I am in need of the firmware updater for the G7.1ut..
I have already emailed both Zoom-NA and Zoom (Japan) said they no longer have the firmware zip (I believe it is called either "E_G7Updater.zip" or ""E_G7Updater106.zip"), so it looks like someone that might still have the file would be my only hope..
Discussion Starter · #8 ·
I do still have decompiled sources for the G7 updater. I'd post them to GitHub, but I'm afraid of the licensing issues. I could try to revert my modifications and build a binary for you, but I'd need an email or something.
please send G7.1ut firmware to my email
1 - 10 of 10 Posts
