Diagram for stock RT452?
1144 Views 2 Replies 2 Participants Last post by  gregk
Does anyone happen to have the stock wiring diagram for this guitar. It uses a 5 way switch and H-S-H pickup configuration. The switch is a Ym-50, the pots are 500k, one is a push pull for coil splitting. I think some other ibanez guitar(s) used this setup, but i dont know which ones. Anyone have a diagram that will make it work right? Thanks!
-Greg
1 - 3 of 3 Posts
Yea, thats the first place I look for my ibanez schems. I found at least one on there that has a coil tap w/ H-S-H pickups, but I cannot confirm if its the same wiring as the RT452 should have stock. I would like to make it as original as possible.
Unfortunately one of the previous owners replaced the bridge pickup with an F2, which I swapped in a V7 to the neck position and moved the old neck pu down to the bridge - eventaully I would like to find the exact bridge pickup model that should be in this guitar.
Thanks!
-Greg
1 - 3 of 3 Posts
