1 - 7 of 7 Posts
The Ibanez RG 7421 had quite a shoulder on the
bass Side of the neck. I spent an hour reshaping the neck with various grits of sand paper. 80,120, 600, 800,1000, 1500, and 2000. I vacuumed all the sawdust up and off the guitar. The neck feels smaller now. It didn’t have that big D shaped shoulder on it when I was done. Neck was oil finished to begin with, so I applied some oil afterward. It is more of a thin C profile now. I don’t have the hump under my left thumb now.
17600
17601
Discussion Starter · #3 ·
That's pretty daring, I'm glad it turned out well! What type of oil did you use to refinish it?
I just used a little fretboard oil. I applied 3 coats. As I play more on it and am more sure of the feel of the neck, I will probably apply tung oil, but that stuff remains sticky for awhile.
I had sanded both sides down, but didn’t remove much wood on the treble side of the neck. The neck had its hump I could feel under my left thumb when playing it. Being on the autism spectrum, I have always had discomfort with things like seams on socks and tags in my shirts, and stuff like that.
I had to remove the hump because I couldn’t play the neck without being acutely aware of the uneven feel of the neck. I notice nothing now when I play it.
Nice work. I need to do this to an old beater I have, which has a strong D profile – dislike that shoulder on the bass side. But first, the kitchen floor poly needs to be stripped off 😂.
Discussion Starter · #5 ·
I had thought about returning the guitar based on the neck profile, but likely any replacement that I could have selected in the Ibanez line might well have had the same issue. The model that I got was an RG4721 which costs $399.00 new. I was quite lucky in that this guitar didn’t have a gloss finish on it, so everything feathered together quite nicely.
Yeah, most RGs (or Ss) have some kind of Wizard neck, so you'd be getting the same basic shape, unless you went with a completely different model, and then you're stuck for 7s unless you want to fork out for an AZ.
Discussion Starter · #7 ·
I did a little more shaping. I would sand a little, then check the feel of it. I re oiled the neck and am letting the oil soak in. As I like it even better now, I guess I will quit while I’m ahead. Don’t want to remove too much material.
The way that it sits in my hand now feels really good. It was just a little too big to begin with.
now that there is absolutely no finish on the back of the neck, it is really fast. I did get a really big pile of sawdust when I was using the 80 and 120 grit. Then I smoothed it all out with 400, 600, 800, 1000, 1500 and 2000 grit. I will just lightly clean it with some steel wool in the future.
Back in the day I had a Stew Mac Tele neck that I reshaped. It was as thin as a wizard neck when I got done with it and I did it asymmetricallay.
1 - 7 of 7 Posts
