1 - 3 of 3 Posts
does anyone think the action on a guitar droped to drop C is kinda sucky?
when i drop i use beefy slinky strings. 54 is the lowest string (C). im gunna drop an rg550 to drop C.
i got to tune the whole guitar now its goona suck it takes forever. the two big screws in the back, i forgot do you screw in or out if your tuning down and getting biger stings? :eek:
.054 sounds a little big.....I tune to B and use the D'Addario Jazz Medium set, 13-56. I would say 11-50 would work just fine. You do need to raise the action a bit when tuning down with heavy strings, due to the larger diameter. When tuning lower with heavy strings, add another spring when going lower than C# for best results. You will probably still need to turn the trem claw screws clockwise quite a bit to get it floating correctly. Hope this is helpful.
Discussion Starter · #3 ·
how do raise the action? what screws or whtever? oh and you know B is only a half a step lower than C so its not that big. iv done it with my j custom. now its time for the rg550.
1 - 3 of 3 Posts
