Hi all,
I have tried something like this below, but it doesn't seem to work entirely. My fourth position doesn't seem to differ from the fifth. It differs between the on/off of the toggle switch (so splitting seems to work), but not 'within' (seems that the bridge and neck are not both selected, it appears to be only the neck). I redesigned it. Could you have a look to see if this should work properly?
I basically want: bridge humbucker, bridge split inner coil, single coil+ inner neck split, dual humbucker, and neck humbucker when the switch is down.
In the fourth position, I want the 'tele middle' when the switch is up (outer coils), and a split neck humbucker in fifth. The third position is a byproduct. I guess there's no other possibilities here (single middle in third and split bridge inner+single middle in second position)?
The rationale for the layout of the third and fourth in switch down is to avoid a large difference in volume when switching from neck to dual humbucker mode (otherwise hopping over the split neck+middle).
I guess I can solve this in the future using capacitors cf. Guthrie Govan.
I hope the drawing is somewhat clear
I am correct that when the switch is down, the upper connections are made, right?
I guess I don't need to link the hot bridge out to ground if I want to select the second coil, correct in the toggle up position (position 4)? The output of the hot is going nowhere, right? (the inner workings of humbuckers are still not entirely clear considering the start wires).
Thanks for any feedback!
