Edge LoPro 1 string too high???
Hi All,
I recently bought a 1992 540-SLTD on eBay. I love the guitar but I swear when I look at the strings from the side (the low E side) the g string is not at the height it should be it's considerably higher than the D. Also seems like the B and E are higher than they're supposed to be.
i emailed Rich at Ibanez rules, he said individual heights always have to be set but it would seem to me that when the bridge comes on the guitar it would be radiused correctly at the factory, no?
*Update*
I can't find the option to delete this thread so I'll just post the fix instead in case someone else has this issue and happens upon it.
Turns out someone had (I guess errantly) put the washer for each saddle screw underneath the saddle instead of on top where it's supposed to be on the G, B and high E strings. SO I put them back where they're supposed to be, tuned, reset the astion, tuned again and bingo - perfect radius! Also, the D string seemed to be buzzing at the middle of the neck where none of the other strings were doing that. Once I got those washers out of there & raised that side of the bridge accordingly I guess it pulled the D string up to where it needs to be because the buzz is also gone. Double Win!
Hi All,
*Update*
