Morning all,
Is there an easy way to change the springs used on the Edge Zero II trems?
Since buying my RG6PCMLTD 2nd hand, it has never been a stable trem system. When you use the bar, it never returns to pitch. I'm not a newbie when it comes to floating trems - and my other guitars do not have this issue.
Things i've done:
Ensure the locking nut is secure.
Ensure the locking nuts are tightened correctly.
Ensure the neck screws are tight and the neck is tight to the pocket.
Replaced the trem posts.
Checked the knife edges.
Added chapstick to trem post recess.
Next is to replace the trem springs. However, these are very, very stiff and I don't want to damage them by installing the new ones incorrectly.
Is there an easy way to do it other than using pliers and pulling them until they fit over the retainers?
Also 2SUX5BA004 is the correct part?
Thanks
James
Things i've done:
Thanks
James
