I'm thinking of changing the Blaze out of my UV7PWH because it's too muddy.
Is the EMG 707 more trebly and higher output?
Yeah, I believe he was the first, in fact, I believe he asked EMG to make a 7-string version of the 81, and they came up with this. Which he says is between an 81 and an 85.sam669 on 7:03 am on April 10, 2002
isnt dino cazares using that emg707? lol, this is a mad pu!!
I'm pretty sure 7-strings and 6-strings use the same tone knobs. But if you mean compared to the ones EMGs use, then you can't do it.. I'm a little confused by the question though. lolShredHead42 said:Doesn't changing the tone pots to the normal ones a 6-string uses help brighten the sound also?
Well, I'm joining the conversation a little, but better late than never. Yes, I put EMG707s in an RG7620, but since then, I've put them in a UV777BK too.becalvert said:Ask Shannon Sharp......He has an RG 7620 with 707's installed and should be able give a better idea of what the differences are.....
