Hi,
I finished the wiring of the 81/85 set. Looks good but sounds bad. When I plug the mono instrument cable in there is a very bad noise/sizzling coming but it disappears after a minute or so. Very interesting. Everything is grounded except the strings (because EMG manual says so).
The diagram I applied is attached. There is only one difference from the original diagram which is the switch I used is a standard Tele 3 way blade switch. To use it I shorted the 6 terminals in the middle to make it 3 pair. I don't know if that's the problem.
Thanks,
Suat
Thanks,
Suat
